Starter Grind on extremely cold starts, starter not disengaging.
Old Jan 21, 2013 | 07:09 AM
patrickvertigo's Avatar
Default Starter Grind on extremely cold starts, starter not disengaging.
Like the title implies, it was about -3F this morning when I started up the EP3. I just bought the car 3 days ago. After cranking the car to start it and the engine firing I let off the key, but the starter stayed engaged to the flywheel and grinded for about a second. It sounded awful. I'm wondering if anyone else has experienced this.
I used to have a 96 civic lx that would do this if it was about -15F. I think it was the same issue. I hate Wisconsin sometimes....
I did find this information also (about halfway down the first page).
https://honda-tech.com/forums/showth...ter+grind+cold
Has anybody tried to repair this, and if so did it actually help? I know that this will be hard on the starter if this happens repeatedly, so I would like to get this figured out. I understand the solenoid may just be stiff do to the temperature being so cold and isn't able to disengage from the flywheel. A new solenoid may help, but who knows..
Any info would be greatly appreciated.
Old Jan 21, 2013 | 07:56 AM
SickSi99's Avatar
Default Re: Starter Grind on extremely cold starts, starter not disengaging.
Mine does this sometimes.
Old Jan 21, 2013 | 08:05 AM
From what I've read, it seems to be pretty common. I just don't want it to eventually destroy the teeth on the flywheel/starter/solenoid...
It would be nice to know if anybody has found a cure for it..
Old Jan 24, 2013 | 05:38 AM
jettadreams's Avatar
Mine does this in the cold, its been around 5 degrees here in Ohio and mine sticks about every morning. I plan on replacing it come spring just because its old. I think it might just be a sign of an old starter as mine did not do this last winter...
Old Jan 24, 2013 | 07:17 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Most of the time there's not much you can do... this bitter cold frozen weather kills EVERYTHING... Only thing you can do is make sure to have the best strongest battery you can to keep strong constant power to the starter. Then also make sure the starter is in good working conditions.
I would check your battery, how old is it? How many CCAs? And then remember your starter is how old and been turned over how many times?
Old Jan 25, 2013 | 05:06 AM
All good points. Battery is a brands new interstate. I think the CCA is 525. Best I could find for a battery that size.
Update on the situation.. The car continues to do this "grind" at any temp below +5F. I was doing some more searching on other forums and websites, seems like there is a way to lubricate the Bendix in the starter. Has anyone tried doing this?
I'm assuming with age, the Bendix gets stiff and has a harder time getting out out the way when the car starts. Also wondering if only that part is replaceable instead of replacing the entire starter.. A DIY would be awesome..
Old Jan 25, 2013 | 05:24 AM
speedooo's Avatar
The started in my ep3 has always done that. Almost everytime when its cold and occasionally in the summer.
Old Feb 4, 2013 | 03:24 PM
turboteg2nv's Avatar
That's good advice, I know my EP3 (when I still owned it) would grind less frequently once I installed my Stinger deep cycle battery. Car starts aggressively even in single digit temps (F').
Sounds like a logical fix, but the starter is a b!tch to access from my understanding. Haven't had the pleasure of replacing mine yet.
Old Feb 4, 2013 | 03:58 PM
Paul 631's Avatar
Mine's had that issue since 50k miles (currently 125k)...
It doesn't sound like the teeth are grinding, just the starter gear is not disengaging in time.
If I have to replace the starter every 100k miles, so be it!
dmanfree
Jun 21, 2013 12:38 PM
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
h22a_black
Feb 13, 2008 06:12 AM
383chevy
Jan 25, 2007 07:58 PM
classciv
Dec 18, 2005 11:53 AM
