Suspension & Brakes Theory, alignment, spring rates....
Lowering springs = no drop URGENT HELP!!!!!!!
Old Jan 20, 2013 | 08:57 PM
RS_Integra's Avatar
Icon2 Lowering springs = no drop URGENT HELP!!!!!!!
Hello honda tech people im new on to this forum and i been searching for ever through the suspension forum and google but cant seem to find it....
My problem is that i have installed some d2 racing sport lowering springs on to my 96 integra..before installing them i read that it takes sometime to notice the drop n i was perfectly fine with that. i installed the front first and when done i notice the drop immediatly and i was very excited :D.. but after alot of struggle with screws snapping in the rear and my bwr lower control arm struggling to get fit in we finally was finish and when we let it go the car stayed its original height . i am wondering can it be possible that i put the spring upside down? is that even possible.. please help i need to fix this asap its suppose to be a 2.5 drop n my front is like that ....
p.s. its been 24 hours since we installed it so yea ive waited please help!!!!
Old Jan 20, 2013 | 09:32 PM
98civdx's Avatar
Master Detailer
Default Re: Lowering springs = no drop URGENT HELP!!!!!!!
Are you sure they are lowering springs? Did you install the springs on the shocks correctly?
And no, it should not settle. That's actually the bushings tearing because you failed to clock them correctly.
Old Jan 20, 2013 | 09:44 PM
PhatBoiOnDiet's Avatar
Your sure installed right? The longer springs go on the front.
Old Jan 21, 2013 | 07:29 AM
GagnarTheUnruly's Avatar
I bet the bushings are holding your car up. Try setting the ride height with the bushing bolts loose and then re-tightening.
Old Jan 21, 2013 | 08:12 AM
RS_Integra's Avatar
Yea i did put the springs in there rit locations correctly but the spring at the back was put upside down i think since the lettering and numbers that were printed on there were back wards.. can that be the case?
Old Jan 21, 2013 | 08:14 AM
RS_Integra's Avatar
Can u be a lil more specific im new to this and am still on a learnin basis...which bushings?
Old Jan 21, 2013 | 08:37 AM
DougNuts's Avatar
Did you roll the car around after installing the springs?
Old Jan 21, 2013 | 08:40 AM
RS_Integra's Avatar
Yes sir especially cuz i had to drive from ct back to ny a good 1hour long ride
Old Jan 21, 2013 | 08:41 AM
At nearly every point where two suspension components meet there are rubber bushings housed in metal collars. If you tighten all the suspension bolts with the car in the air, the bushings will twist when the car lowers and they will act as springs, holding the car up. So you need to lower the car with the suspension bolts loose, and then tighten them all with the car at ride height. This only happens with rubber bushings, so if you have urethane bushings something else is going on.
Old Jan 21, 2013 | 09:56 AM
RS_Integra's Avatar
Im not 100% sure wat bushings i got but i believe its urethane my car is completly stock only upgradfes has been the lowering springs and my lower control arms.
Old Jan 22, 2013 | 06:13 AM
spAdam's Avatar
Loved
Community Favorite
You need to reclock those bushings before they get destroyed. Whoever told you tha the car will lower over time is an idiot.
AFAccord
Apr 30, 2011 08:04 PM
million
Jun 7, 2007 04:36 AM
cantofreak
Mar 1, 2006 11:34 PM
phylast
Oct 27, 2005 10:23 AM
Suzukablue
15
Feb 16, 2005 05:57 PM
