Where can I find a good gasket for Downpipe
Old Jan 20, 2013 | 07:06 PM
Mishako129's Avatar
Default Where can I find a good gasket for Downpipe
Does anyone know where i can get the copper or metal gaskets for my 91' accord downpipe? My crappy graphite gasket blew out on me. I have an aftermarket header/downpipe so anything OEM is out of the question, no ring type gaskets will work.
The only thing I found was a gasket for a Land Rover, will this work? It appears to be metal:
http://www.ebay.com/itm/EUROSPARE-OE...item3a7ca5adba
Old Jan 20, 2013 | 09:24 PM
holmesnmanny's Avatar
Default Re: Where can I find a good gasket for Downpipe
Have you actually measured the opening ? Just because it's aftermarket doesn't necessarily mean an oem size gasket won't fit.
Old Jan 20, 2013 | 09:25 PM
Keep in mind that even OEM gaskets need to be lightly tapped in before torquing. What you think might be too small might be the one you need.
Old Jan 21, 2013 | 12:17 AM
Mishako129's Avatar
Notice how there is a place for a ring gasket on this downpipe. This is a dowpipe with OEM gasket fittings,
Now this is the downpipe that I have. Notice how there's just a flat gasket surface with not ring groove,
so an OEM gasket will not work.
Old Jan 21, 2013 | 12:28 AM
Mishako129's Avatar
There's people on Cb7tuner.com who used this Subaru Legacy gasket before, so I would imagine the one I listed would fit as well.
Old Jan 21, 2013 | 12:40 AM
ok some exhaust shop tried to use one of those gaskets on my car even tho I had a spot for the oem gaskets, that's why I asked if you were sure. Have you tried contacting your ebay seller ? I'm assuming it's ebay...but obviously whoever u bought it from.
Old Jan 21, 2013 | 12:45 AM
Mishako129's Avatar
I have not contacted the seller. Fact is, most cheap aftermarket pipes are just made that way. The downside of that is you have to buy these cheap, crappy graphite / metal gaskets that don't work very well and blow out the first time you use them. These are what I mean, Ebay says they're selling like crazy.
Look here, it says "100 sold". Its because these gaskets are crap and people keep buying them... but they're the only ones that fit the aftermarket header.
Old Jan 21, 2013 | 12:47 AM
I know dude, the very first one I had was that type but when I tried to pass carb they told me it won't pass lol
actually they shouldn't really blow out, mine did last..it's really important to torque each bolt a lil bit at a time in several stages to keep it from leaking.
1990IntegraLS
Apr 1, 2018 10:32 AM
Eghatchgsr8
Sep 19, 2014 02:24 PM
chasmataz
Jul 25, 2010 08:35 AM
gofastgokart99
Jan 7, 2008 10:59 PM
pnjbiboye
Sep 14, 2007 12:35 PM
