Need motor mount help!!!
Old Jan 20, 2013 | 09:20 AM
D16Z6-89CRX's Avatar
Icon2 Need motor mount help!!!
So I bought a 1989 Honda Crx HF that already had the D16Z6 swap, but with the hydro transmission( Stupid I know they should have used the Si trans). My issue now is the lower transmission/motor mount is not on there. The one that is below the radiator. I just need that mount to fix this swap, I have found them in sets for like $400.00. I dont need the set just the one that I mentioned. If someone could lead me in the correct direction on this that would be awesome or if you have one for sale that would work also.
Thanks
Old Jan 20, 2013 | 10:16 AM
First.EG's Avatar
Default Re: Need motor mount help!!!
Don't hydro transmissions not have the provision for that mount?
Old Jan 20, 2013 | 11:25 AM
I'm not sure exactly what your asking or stating
Old Jan 20, 2013 | 09:00 PM
Mill-town2uner's Avatar
Most of the swaps I've seen in them cars and the hatch's didn't run a front mount ....., but they all been b-series ..... Is there a reason or prob that you want the mount in ?? Are the mounts in the car that are use oem or aftermarket. ???
Old Jan 20, 2013 | 09:28 PM
myhonda99's Avatar
Yea I don't see them in hatch's
Old Jan 21, 2013 | 03:30 PM
Yeah im getting a lot of shifting in the motor and trans and just feel that if I had that mount it would eliminate that.
Old Jan 21, 2013 | 10:27 PM
First.EG's Avatar
I'm not sure my self but like the other guys said b series eliminates that mount.
Does the trans have thread holes there for the mount?
Old Jan 21, 2013 | 11:05 PM
civickiller's Avatar
you talking about the one on the cross member, right?
might be easier to buy the motor mount inserts
Old Jan 21, 2013 | 11:19 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Don't think you can add a mount there with a hydro tranny. That particular mount I have only seen on cable trannies. Might consider getting stiffer mounts to compensate for it. Hasport 62a would be my recommendation
Old Jan 22, 2013 | 08:37 AM
It's for a d16z6 swap ... I check the firmness of the other mounts and see what I come up with. Right now I just don't have the funds to spend 400 on a hasport motor mount kit. I might just weld one up and see what happens.
Old Jan 22, 2013 | 08:39 AM
jdmkid91's Avatar
Bump tttttttttttttttttttt
Old Jan 22, 2013 | 08:41 AM
Yeah there's threaded holes there for one.
Old Jan 22, 2013 | 08:43 AM
Anthony916's Avatar
bump
atleast-3
Sep 23, 2007 12:07 AM
90redintegra
Dec 8, 2006 06:17 AM
staticrex
Jan 14, 2005 03:34 PM
Train
Jun 12, 2003 10:28 PM
