civic si 00 stock pipe diameter
Old Jan 20, 2013 | 03:29 AM
ribal_gh's Avatar
Default civic si 00 stock pipe diameter
Hello,
Please i need only 100% accurate answer.
I have read several posts, some saying its 1.75" others 2.0" and even 2.25"
I want to buy a header for my b16 so i need to know what collector size should i get!
thx
Old Jan 20, 2013 | 09:04 PM
ribal_gh's Avatar
Default Re: civic si 00 stock pipe diameter
bump!!!
Old Jan 21, 2013 | 09:27 PM
ribal_gh's Avatar
should i be hopless!! no body got an idea!!
Old Jan 22, 2013 | 01:57 AM
eghatch9295's Avatar
Stancetard Hate Monger
2.25
Old Jan 22, 2013 | 02:34 AM
BlackDeuceCoupe's Avatar
HT White Ops
Originally Posted by ribal_gh
Hello,
thx
It all depends on where you measure it.
I have a '99 B16A2 Si motor in my ride. I blew out the stock cat, when I puked a distributor, a while back.
I just went out in the garage and measured it.
The flat flange that mounts to the collector is indeed 2.25", but that includes the area for the metal squish ring. The tube diameter is actually closer to 2".
The exit diameter (the side with the "donut" gasket) is tapered. Basically, it's 2", but the inside diameter of the pipe is about 1.75".
So, I guess all of those sizes are correct, depending on where you measure it.
Old Jan 22, 2013 | 02:46 AM
ribal_gh's Avatar
woww, thats great details.. thanks man.
so mainly i should look for a headers with 2.25" collector.
Will a 2.5" work?
Old Jan 22, 2013 | 06:48 AM
JuggerNaut-CTR's Avatar
On a b16 I would go with 2" everything...2.25" at most
I had 2" on a stock sir2 b16 a while back and switched out to 2.5 and lost quite a bit of low end, which on a b16 you need the most of.
ghostsi69
Jan 12, 2005 10:19 AM
.water
Jun 20, 2004 09:21 PM
myhatchrips
Feb 23, 2004 08:18 PM
Nameless RB26
Feb 17, 2004 10:22 PM
