1994 acura integra idles like its misfiring
Old Jan 20, 2013 | 02:07 AM
egvr4's Avatar
Default 1994 acura integra idles like its misfiring
changed plugs, wires, cap, rotor, even changed fpr and fuel filter and car still has funny idle. Seems lost of power a little bit. The idle does not go up and down, it holds steady rpm just choppy idle. I hope someone can help. Thanks
Old Jan 20, 2013 | 09:06 AM
GagnarTheUnruly's Avatar
Default Re: 1994 acura integra idles like its misfiring
Check ignition and cam timing. Check valve clearances, and test spark. Also test fuel pressure and do a PCV valve test (pinch the vacuum hose of the PCV valve and listen for a "click." Is the problem temperature dependent?
Old Jan 28, 2013 | 07:19 AM
Nsx2007's Avatar
PVC valve? Also timing
Old Jan 28, 2013 | 07:41 AM
mpgmike's Avatar
A compression test would rule out engine issues in short order. Give it a try.
Mike
bigturner87
Nov 8, 2014 10:09 AM
Ephosay
Nov 16, 2013 04:45 AM
civicvx1992
Jun 9, 2013 11:58 PM
FBPPrelude
Dec 27, 2006 07:12 PM
Cone
Jun 23, 2003 02:51 PM
