92 prelude revs increase when put in drive
Old Jan 20, 2013 | 01:11 AM
dedbike's Avatar
Default 92 prelude revs increase when put in drive
when i warm me prelude up it revs way to high when i put it in drive until it the temp gauge get to half even though sometimes it even does it then until i give it a good rev any one can tell me
Old Jan 21, 2013 | 08:42 AM
go-part's Avatar
Default Re: 92 prelude revs increase when put in drive
It could be your IAC that is causing your idle to be so high.
See if cleaning it helps
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old Jan 21, 2013 | 10:19 AM
mpgmike's Avatar
Something I've run into in the past is the throttle cable getting pinched causing the throttle to not quite release. Check for fluid operation of the cable within the sheath.
Second, make sure your throttle return springs are intact and not hitting against anything.
Third, take a can of carb & choke cleaner and thoroughly clean around the throttle plates, as well as every port in the TB. Make sure you have no green or white crud building up in the IAC or TPS connectors (or anywhere else for that matter).
We're seeing this through your eyes, and you haven't given us a whole lot to go on. I hope this gives you a place to start.
Mike
Old Dec 14, 2013 | 09:04 PM
dedbike's Avatar
thanks for that all we got two preludes now and prob gettin another one and my daughter has an excellent one 2,2 manual
Old Dec 17, 2013 | 05:23 PM
awesomeguy641's Avatar
It could be the fast idle valve. Bad map/ tps/ iacv/ coolant temp sensor
Kman1371
Feb 14, 2017 08:22 AM
realrawjbizz
Jul 5, 2011 11:21 AM
cdmef
Jul 3, 2011 06:03 AM
huskerpower02
Apr 27, 2005 07:58 PM
neoh74
Aug 12, 2004 10:43 AM
