Car skirt on roads and highways
Old Jan 19, 2013 | 04:14 PM
creation25's Avatar
Default Car skirt on roads and highways
Please help me locate this problem I'm having. When driving on normal roads and or highways we know there are slight bumps. Every time I come across a small bump my car always skirt from underneath and the car hops/bounce. It squeaks every time it skirt. I remember about a month ago I took my car to the shop to get a universal horn installed right below the driver's dashboard. Later that day when I came back home the air dam behind my front bumper totally came off. I then threw it away. Could that be the problem? I also notice that when i pick up 1st gear it is really weak now. So I'm curious where this squeak noise is coming from? Anyone have any idea? I drive a 92 hatch. Any help would be grateful.
Old Jan 19, 2013 | 04:43 PM
weavertime1's Avatar
Default Re: Car skirt on roads and highways
Way too vague here...Are your tires good? Is your suspension stock or has it been messed with...Either way, is it still functioning correctly? How is your steering rack? There are a ton of things that could cause this problem, but if it is as bad as you say, the problem should be pretty evident.
Old Jan 22, 2013 | 04:04 AM
creation25's Avatar
Tires are good. Suspension has not been mess with. The steering wheel is somewhat crooked after the mechanic shop installed a horn in it. I can hear some cracked noise when I turn the steering wheel. It gets irritated. Could that be the problem? My car has never had this skirt problem before they installed the horn in it. Every time I go on the road the car always hop even on small bump, then the car would skirt down the left bottom side of the car. Not the right side. I know the air dam behind the front bumper came off and it was on the left side too. Any idea?
Old Jan 22, 2013 | 07:16 AM
creation25's Avatar
bump
Old Jan 22, 2013 | 07:38 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Why not take it back to the place that did the work on it?
Old Jan 22, 2013 | 08:05 AM
dirty19's Avatar
Ridin Dirty in Cali
skirting ...........? is this like slapping the ground with an overly lowered car?
Old Jan 22, 2013 | 08:26 AM
doctorake's Avatar
Community Builder
Is your car "slammed" and or "stanced" OP?
Old Jan 22, 2013 | 09:08 AM
HeadkickHarris's Avatar
Not too sure what you mean by "skirting" but my car scrapes when taking a turn too sharp. Its just my plastic shroud under my motor, around my subframe. maybe a video if possible?
Old Jan 22, 2013 | 10:57 AM
creation25's Avatar
Yes that! when going on roads the car keeps skirting like that with a 'sssssssss' noise.
Old Jan 22, 2013 | 11:17 AM
doctorake's Avatar
Community Builder
Look under it and see what has scrape marks. Once you figure out what is scraping then raise the car up to a height that it does not scrape.
Old Jan 23, 2013 | 02:12 AM
Since it happened after the horn install, check the front bumper underneath where it attaches to the bottom of the radiator support. To install the horn correctly you would have to at least partially remove the front bumper. Maybe the mechanic didn't put it back on correctly.
Old Feb 4, 2013 | 10:21 AM
creation25's Avatar
I can't believe anyone here haven't a clue what I'm talking about. I went to the grocery store today and someone told me it's the air velt or something that is causing the skirt. It keeps on cranking up and down. Does anybody know exactly what it is called again?
Old Feb 4, 2013 | 10:31 AM
doctorake's Avatar
Community Builder
If you are having trouble describing the problem and what is causing it how are we supposed to know the solution?
Old Feb 4, 2013 | 10:42 AM
creation25's Avatar
When you have sex on the bed it squeaks. I don't know a better way to describe it. When the car go on the road once it come to a bump it will skirt badly. Yes my car is low but that's not the reason why. I know it has to be something else. When I do sharp turns it squeak/skirt badly.
Old Feb 4, 2013 | 11:13 AM
doctorake's Avatar
Community Builder
Did you look under it to see what is scraping?
Old Feb 4, 2013 | 11:16 AM
creation25's Avatar
There is nothing underneath it. No hanging, nothing.
Old Feb 4, 2013 | 12:00 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Definition of "skirt" as a verb, as you are using it in this post, according to Merriam-Webster. If none of these definitions apply, then I will submit that your description of the problem is inadequate/inaccurate.
skirt
verb
Definition of SKIRT
transitive verb
: to form or run along the border or edge of : border
a : to provide a skirt for
b : to furnish a border or shield for
a : to go or pass around or about; specifically : to go around or keep away from in order to avoid danger or discovery
b : to avoid especially because of difficulty or fear of controversy <skirted the issue>
c : to evade or miss by a narrow margin <having skirted disaster — Edith Wharton>
intransitive verb
: to be, lie, or move along an edge or border
skirt·er noun
Old Feb 4, 2013 | 12:10 PM
98civdx's Avatar
Master Detailer
What the **** is going on in here?
The car is clearly too low, and you need to find out what is "skirting." What ever that means.
Old Feb 4, 2013 | 12:38 PM
deschlong's Avatar
Loved
Community Favorite
Indeed, except for the fact that the OP has OEM suspension, as far as I can make out from his posts.
Old Feb 4, 2013 | 12:45 PM
SiRCiviC94's Avatar
Op means skidding. Are the wheels stock?
Old Feb 4, 2013 | 12:48 PM
doctorake's Avatar
Community Builder
He stated it was "low"
Old Feb 4, 2013 | 01:10 PM
98civdx's Avatar
Master Detailer
That's what I read at first, and then I saw him say the car is low?
Old Feb 4, 2013 | 01:18 PM
deschlong's Avatar
Loved
Community Favorite
Totally confusing. I think I'm bailing out of this thread.
Old Feb 4, 2013 | 01:51 PM
strategy400's Avatar
WTH does it mean for your car to SKIRT?
Old Feb 4, 2013 | 02:48 PM
doctorake's Avatar
Community Builder
