94 GS-R running rich. out of ideas
Old Jan 19, 2013 | 03:05 PM
B_Swapped93's Avatar
Post 94 GS-R running rich. out of ideas
black dust/dots on the rear bumper. plugs were very black and black smoke when you rev it(below 5k). Car ran fine up until i installed my S2 IM/TB. This is really starting bug me im out of ideas. i've searched but im just hitting dead ends on why it's doing this.
Old Jan 19, 2013 | 06:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 94 GS-R running rich. out of ideas
Get it tuned.
Old Jan 20, 2013 | 02:50 AM
HondaPartsHero's Avatar
Technical Hero
Mods? ECU? Any check engine lights?
Old Jan 20, 2013 | 03:11 AM
It's tuned. mods:S2 megapower exhsust,bigtube header,SRI,S2 70mm TB,S2 intake manifold. chipped p72 for all mods listed above. just one cel but it only comes on when the car is running so i can't read it.(missing knock and evap purge valve but that's it)
Old Jan 20, 2013 | 03:22 AM
Technical Hero
You can read it when the car is on. Jump the service connector on the passenger floorboard and count the blinks. Honestly though a "chip" for mods isn't tuned, you need a tune able ECU and a dyno and/or an experienced professional to tune it.
Old Jan 20, 2013 | 03:33 AM
@HondaPartsHero thanks i never knew you could with it on. i just don't have 500 or so for a Hondata or simmiler.
Old Jan 20, 2013 | 04:02 PM
TKATS_EF's Avatar
check for vacuum leaks. the 02 sensor may be trying to compenstate for the lean condition if it does have a vacuum leak or a bad exhaust header gasket. Where is your 02 located on the header? the only other time ive seen black soot come out pf the tailpipe is when theres a burnt valve. Hope its nothing serious but check for vacuum leaks. But if you could get that code it would be even better
Old Jan 20, 2013 | 04:41 PM
Still have to check for vacum leaks. but the only 02 is located at the end of the header. header gasket is near brand new, will try and get code tomorrow.
Old Jan 20, 2013 | 05:21 PM
TKATS_EF's Avatar
sounds like a good start in order to find the problem. keep us posted on what you find
Old Jan 20, 2013 | 06:56 PM
beecee18's Avatar
You have to be kidding me,
you have another thread open about your car not reaching op temp for a long time which we determined must be the thermostadt failed or stuck open, installed backwards, ect.
Test replace and fix your cooling system problem first as the ECU is gonna run off of richer tables when running that cool for startup enrichment, your probably not even entering closed loop fueling, THAT is where the soot on your bumper is coming from, and THAT is why your vehicle is overfueling.
If the thing has been running for a while and hasnt heated up, feel the upper radiator hose and inspect whether the hose is hot and pressurized.
I bet your car idles 900-1000 rpm until it finally warms up also
Old Jan 20, 2013 | 07:09 PM
hose gets hot and is pressurized after a while. my car idles at 1.7k upon start up and will not go down even when car is at op temp(S2 tb has not FITV) so i have to bring it down by losening the throttle cable bolts(i have a thred in the all motor regrading that issue)
Old Jan 21, 2013 | 09:01 AM
vacum leak between the TB and IM gasket is fine but will need to get new bolts i lost 2 of the 4 . and i can't read the code im getting @hondapartshero i tried but it won't work, with the car on and the connector shorted/jumped. nor with it show with the car in the acc postion.
TinoNT
Apr 25, 2013 07:55 PM
attack666
Sep 27, 2011 01:52 PM
rice h8r
Jun 27, 2010 10:51 AM
jiggy
12
Sep 22, 2004 12:16 AM
slimbo
Apr 11, 2002 05:23 AM
