need to have good handling by saturday... what should i get?
Old Oct 20, 2002 | 04:28 PM
tegasaurus's Avatar
Default need to have good handling by saturday... what should i get?
I was offered by some guys to join them at some road corse (not auto cross, but an actual road corse race). My teg is pretty quick and i jsut replaced the clutch and flywheel... i have i/h/c/e and pullies with a full ignition.. i know this will help me on the straights, but what im concerned about is my integra handles the turns. I know the best thing i could do is take all the unneccessary **** outa my car (which im going to do) but what else should i get to improve my handeling that won't put me WAY out of budget. I have H&R Springs, Front upper strut bar, 16" slipstreams with 215/45 falken azenis...
thanks,
Ryan
Old Oct 20, 2002 | 04:31 PM
Understeer's Avatar
Default Re: need to have good handling by saturday... what should i get? (tegasaurus)
22mm rear sway bar.
Old Oct 20, 2002 | 04:38 PM
GSRrR's Avatar
Default Re: need to have good handling by saturday... what should i get? (Understeer)
Get BSQ's mounting kit and the itr sway bar. Mine are in the mail.
Old Oct 20, 2002 | 04:39 PM
tysf's Avatar
some decent shocks and a rear swaybar should do nicely
Old Oct 20, 2002 | 04:48 PM
Fuuma0083's Avatar
Default Re: need to have good handling by saturday... what should i get? (GSRrR)
Struts, strut bars (front, rear), C pillar bar, tires (Falken Azenis)
*i know i'm missing more but datz good enough*
Old Oct 20, 2002 | 04:54 PM
garados's Avatar
Just get an upgraded rear sway bar and some new shocks
Old Oct 20, 2002 | 07:03 PM
tremor86's Avatar
Default Re: need to have good handling by saturday... what should i get? (garados)
Rear Swaybar, Rear lower tie bar (neuspeed), and shocks (kyb agx's, tokiko blues)
Old Oct 20, 2002 | 07:07 PM
sutrusu's Avatar
Default Re: need to have good handling by saturday... what should i get? (tremor86)
i dont suggest going to the track on a "new to you" suspension...
Old Oct 20, 2002 | 08:14 PM
Caffeine Slug's Avatar
Default Re: need to have good handling by saturday... what should i get? (sutrusu)
agreed...you know how your car handles as it sits right now. if you get the bigger rear sway bar, that could put you in a situation where the back end will come around unexpectedly (just from lack of experience). So go to the track event, have fun, and save the upgrades for afterwards.
Which track are you going to, Firebird?
Old Oct 21, 2002 | 12:48 PM
BlueTeg's Avatar
second that.
It took me a couple of days to get the hang of my swaybar.
You have to get a feel for how hard you can push the car, and how much throttle lift will cause oversteer at what throttle levels.
Old Oct 21, 2002 | 01:30 PM
allmotorls95's Avatar
Default Re: need to have good handling by saturday... what should i get? (BlueTeg)
get a big brake kit...
Old Oct 21, 2002 | 01:41 PM
BlueTeg's Avatar
Default Re: need to have good handling by saturday... what should i get? (allmotorls95)
Correct me if I'm wrong but those need a 500 mile break in period don't they?
Old Oct 21, 2002 | 01:47 PM
Edited post...just realized he was talking about doing track event, not autox. Sorry!
[Modified by Caffeine Slug, 2:49 PM 10/21/2002]
Old Oct 21, 2002 | 01:49 PM
Default Re: need to have good handling by saturday... what should i get? (Caffeine Slug)
y would u want a 13" wheel for better handling ...
Old Oct 21, 2002 | 01:53 PM
See above retraction - I was thinking autox, not track. While a 13x8 or so wheel is nice for autox, it's not really helpful for track events.
I'll shut up now.
Old Oct 21, 2002 | 01:54 PM
Jesse H's Avatar
Shorter tires, better gearing.
You'd have to find a wide 13" wheel and tire.
Old Oct 21, 2002 | 02:00 PM
Web_Head's Avatar
New User
Did you make sure your camber adjustments are right after the new supension and wheels. Sometimes larger wheels reduce your tires contact patch if your supension is not adjusted right. Makes the tires look like this --- / \. They will wear funny too.
Old Oct 21, 2002 | 04:05 PM
stumpyf4's Avatar
Default Re: need to have good handling by saturday... what should i get? (Trench)
I agree with everyone else... don't do anything to drastic. Plus your don't really want to your shake down during a race situation. Change the oil, bleed the brakes and drive hard!!
Old Oct 21, 2002 | 05:13 PM
Deke's Avatar
Default Re: need to have good handling by saturday... what should i get? (stumpyf4)
Ryan: Post a pic of youre teg w/ those slipstreams!!!
Old Oct 21, 2002 | 05:30 PM
Jesse H's Avatar
Default Re: need to have good handling by saturday... what should i get? (Deke)
...in the appearance forum
dj theoretic
11
Jan 18, 2009 11:49 AM
Jdmls
Jun 8, 2007 11:57 AM
. o 69 o .
Aug 3, 2003 07:30 AM
the DR.
Aug 20, 2002 10:20 PM
fstgsr
Jun 8, 2002 01:45 PM
