Car wont start unless i jump the solenoid!
Old Jan 19, 2013 | 12:25 PM
leoquino_eg's Avatar
Icon3 Car wont start unless i jump the solenoid!
When I try to start all it does is whirr, so i replaced the starter and still acts the same. I took it to a buddy of mine and he jumped the solenoid and it turned right on. I've been doing it like that ever since. This one night i was turning it on, it sparked more than usual and started to turn on normally but is back at it again. Any help is appreciated! Its a 93 eg hatch
Old Jan 19, 2013 | 04:57 PM
weavertime1's Avatar
Default Re: Car wont start unless i jump the solenoid!
Check the cable running to your starter from the battery. Also check to see that the starter signal wire is still properly attached. I believe there is a fuse for starter signal as well under the dash. Good luck!
Old Jan 19, 2013 | 05:28 PM
Former User's Avatar
Did the notorious rubber stopper (red arrow) at the top of the clutch pedal fall out?
Old Jan 19, 2013 | 06:56 PM
I have seen that happen as well...
Jmx305
12
Dec 9, 2013 03:20 AM
Offspring EK
22
Dec 9, 2009 04:55 PM
jayzonmyfeet
Dec 16, 2006 09:08 AM
Zulu888
Sep 28, 2003 09:28 AM
curiousgpnoy
Jun 25, 2003 08:43 AM
