91 Ef LS Swap Issues
Okay so we got the engine in with no problem.. Had a little issues with getting it to run with out missing, fixed that. Well we took her out for a gentle ride to the gas station and filled her up. Well on our way back my buddy says "Get on it a bit," so i did. Well wound out first gear, hit second did the same, hit third same thing, left off put it in 4th and let the speed drop (i was going about 80 in a 35) as she slowed down i went to give it some gas and you heard it want to go but it seemed to bog out every time i hit the gas then it died.. Gave us some problems starting then it fired up and we went back to his place to figure this out and we are stuck... Any ideas what could be going on? Would appreciate all the input and suggestions you all have!
Thanks in Advance!
-Justin
Thanks in Advance!
-Justin
Sure sounds like a vacuum leak. Better check all the lines to make sure they're still on and if so, check for cracks or splits in the hoses. Usually happens at the connection points..
Natsu09
Jan 23, 2018 04:07 PM
