what temp should cooling fan come on
Old Jan 17, 2013 | 11:31 PM
jenishereto's Avatar
Default what temp should cooling fan come on
93 del dol put new thermostat in and had tem gauge in the radiator neck it got up to about 225 and still the fan didnt come on ! what is the ballpark temp that the fan should come on ?
Old Jan 18, 2013 | 12:42 AM
axis11's Avatar
Default Re: what temp should cooling fan come on
My fan comes on at about 203 degrees F +/- a few degrees. Can't remember what the manual say but its close to this.
Old Jan 18, 2013 | 09:02 AM
Former User's Avatar
See diagram from the 92-95 Civic service manual:
Old Jan 18, 2013 | 10:33 AM
Vagitarian's Avatar
225 coming out of the head at the water neck is not to high, that is the water that is just leaving the engine and would be the hottest.
The stock coolant fan switch sees coolant that has gone through the radiator and turns the fan on no later than 205, and which point the water coming out of the head is probably 225-230 and is fine
Definetely verify your fan comes on though
Pure Sol
Apr 20, 2011 04:01 PM
walrus_07
Feb 21, 2009 10:16 PM
rextec
21
May 17, 2006 05:43 PM
turbotime
Nov 14, 2005 12:45 PM
vtec69
Jan 16, 2003 08:06 AM
