milling the head 11.0.1 pistons
Old Oct 20, 2002 | 03:44 PM
migo's Avatar
New User
Default milling the head 11.0.1 pistons
I've milled my head..I took off .40 thous off and running 11.0:1 pisttons, and the block has not beened decked..
What kind of compression am I running, I think I'm close to 11.4:1 or 11.5:1
Old Oct 20, 2002 | 04:45 PM
brian b's Avatar
New User
Default Re: milling the head 11.0.1 pistons (D.SPECS)
on the B heads .007 is good for about .3:1 at 3.192 bore.. so you should be around 12.7:1 now. if you can measure the cc of the head i can give you a better idea.
Old Oct 20, 2002 | 05:03 PM
rainmanEK's Avatar
big strong guy
Default Re: milling the head 11.0.1 pistons (brian b)
.0040 thousands = 1mm should yeild slightly over 1 full point! perhaps aound low 12ish cr! correct me if im wrong, not to up to date with h series!! eric
Old Oct 20, 2002 | 06:54 PM
migo's Avatar
New User
Default Re: milling the head 11.0.1 pistons (rainmanEK)
HOLLY SH*T...thats kinda high and good
anybody heard of using clay to measure the cc, just a thought
Old Oct 21, 2002 | 10:17 AM
brian b's Avatar
New User
hmm yeah i guess you can do that, pack it with clay and then find out what one cc of clay weighs.. we usually drop water in through a flat piece of lexan
nitroaccord105
Jan 23, 2007 08:55 PM
canada-civic
Mar 1, 2006 07:50 AM
asubennett
Jun 10, 2004 04:10 PM
Mentat Ghola
14
May 11, 2004 02:35 PM
BeavisB16
Feb 22, 2003 12:28 PM
