Want to know good brands for pistons
Old Jan 17, 2013 | 05:39 AM
brandonw95's Avatar
Icon2 Want to know good brands for pistons
I have been told of many different good brands for pistons but i want some more opinions. i have an ls block and i am going to put high compression pistons but i am not sure if i want 11 to 1 of if i want 12 to 1 compression ratio and what brand to get so can i please get some opinions
Old Jan 17, 2013 | 05:44 AM
JuggerNaut-CTR's Avatar
Default Re: Want to know good brands for pistons
More details on goals for the build would be helpful. What else is going to be done to need the 12:1 compression?
Do you have a budget? I can list several pistons for you but how do I know if you can afford it...
I personally would get a slightly larger oem piston...81.5mm p30 in a ls does quite well with a larger cams
Old Jan 18, 2013 | 05:46 AM
brandonw95's Avatar
i am going to fully build the block and most of the head but it is going to be a daily driver and take it to the strip sometimes and just toy around with it but i dont want to spend over $700 for the pistons
Old Jan 18, 2013 | 11:31 AM
Eg.ls.turbo's Avatar
I like cp pistons. I have them in my ls turbo setup wit eagle rods, haven't failed me yet. And I've seen a lot of racers use weisco too. The cp i bought were like $400 with rings and wrist pins and pins. Those would be the best two choices since a lot of import racers use them that's my opinion though.
Old Jan 20, 2013 | 03:45 PM
fitted2k9000's Avatar
Supertech High Performance Forged Pistons
http://www.jhpusa.com/store/pc/viewP...idcategory=334
Arias-Pistons
http://arias-pistons.myshopify.com/c...ct+acura+honda
ben_art
13
Dec 2, 2014 03:09 PM
Beasting EF22
Jan 14, 2012 05:48 AM
Khmerican
Jun 6, 2007 09:35 AM
gassaversracing
Feb 11, 2005 02:54 AM
lsteggy
Oct 16, 2002 05:49 PM
