Honda CR-V & Element 2WD & 4WD Element & CR-V
*Official H/T OFFROAD/LIFTED CR-V thread!*
Old Jan 17, 2013 | 05:20 AM
4cylfiend's Avatar
Default *Official H/T OFFROAD/LIFTED CR-V thread!*
Since the last one was a thread inside a thread, I figured we should start a new one.
-Post up pictures of your Offroad/Lifted CR-V!!
I'll start with mine:
2001 Electron Blue Pearl Honda CR-V
5 Speed
15x7 (0 offset) Crager Soft8 with 8mm spacers
Old Man Emu springs
Old Jan 17, 2013 | 02:15 PM
ARMED's Avatar
Default Re: *Official H/T LIFTED CR-V thread!*
nice
Old Jan 17, 2013 | 02:52 PM
civiceg94's Avatar
this will be a really good thread
Old Jan 18, 2013 | 05:25 AM
4cylfiend's Avatar
Originally Posted by ARMED
nice
Thanks man!
Hope so! There are a lot more people buying CR-V's. Just thought this would help the CR-V section a little more organized.
Old Jan 20, 2013 | 03:58 PM
ZCcivic91's Avatar
Nice. Id love to see if anyone has any pictures of a lifted 1st Gen CRV with factory wheels and tires (or factory size anyway)? Post it up if you do please!
Old Jan 20, 2013 | 06:09 PM
2000crv sport's Avatar
can we post pictures off crv's with just bigger tires too ? off roady looking v's ? and can u change the name of the thread then too ?
Old Jan 20, 2013 | 06:27 PM
Dc2_ShowStopper's Avatar
Nice Crv . I just purchased mine 2 weeks n I can't wait to modify mines.
Old Jan 20, 2013 | 08:59 PM
evilclown312's Avatar
4cylfriend, did you have the CRV at IFO in ohio Fall last year?
Old Jan 20, 2013 | 11:32 PM
Caddiman's Avatar
i want a crv!!! that ebp is sexy
Old Jan 21, 2013 | 04:51 AM
4cylfiend's Avatar
Yep! Post away! I have edited the thread title as well. Good suggestion!
Thanks man! You are gonna love it.
Yep, I was there in Columbus for IFO twice last year. This year I will be a participant
Thanks alot brother. I suggest you get one, there is something about them that makes them alot of fun.
Old Jan 21, 2013 | 08:55 PM
Default Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Haha, thought i remembered seeing this their! You had it posted up by the fence i believe. Why i remeber IDK. Ill be out there this year as well!
Old Jan 22, 2013 | 03:48 AM
LDForget's Avatar
not really lifted, but giant tires with my coilovers all the way up.
Skunk2 Accord Sleeve Type Coilovers all the way up without too much preload.
225/60r18 Firestore Winterforce tires on 2011 Ralliart 18" rims.
Old Jan 22, 2013 | 05:03 AM
4cylfiend's Avatar
Haha yep, posted! Must have been walking by seeing, Car-Car-Car-WTFISTHAT-Car-Car, Etc. Haha.
Your Crv looks good man. Do you have any issues with rubbing at all?
Old Jan 22, 2013 | 05:15 AM
LDForget's Avatar
thanks. rubs at full lock even after some smashing and grinding. some wheel spacers would fix it but its not worth it as its in winter mode and will never be winter driven again.
Old Jan 22, 2013 | 07:32 AM
i64X's Avatar
Here's mine. Lifted on OME springs and Sensen struts.
Seriously considering the Soft8's because I want the more aggressive offset now that it's actually lifted.
Old Jan 22, 2013 | 07:56 AM
4cylfiend's Avatar
Your CRV is in really good shape! I love the color, but I may be partial to it as well
What size tires do you have on it now?
Old Jan 22, 2013 | 07:59 AM
i64X's Avatar
Wheels are 15". Tires are 215/75/15.
Old Jan 22, 2013 | 08:01 AM
4cylfiend's Avatar
Ahh I gotcha. Same size as mine then.
Old Jan 22, 2013 | 08:56 AM
i64X's Avatar
Just ordered the Cragar D-windows off of Summit, along with some 1/2" spacers. 15x7 6mm offset +4.25" backspacing. Should be rad. :-D
Old Jan 22, 2013 | 09:07 AM
4cylfiend's Avatar
Those 1/2" spacers are gonna put them out there! That will look really good. I would just make sure you have enough thread sticking out of the studs.
Old Jan 22, 2013 | 09:11 AM
i64X's Avatar
Yeah I'll definitely test fit it first before having the tires dismounted from my existing wheels. OSX2000 ran basically the same setup on the same wheels and said that due to the decreased thickness of the steel wheels vs typical aluminum wheels it pretty much balanced out almost exactly. I was just trying to find the old thread about it. Makes sense though, since steel wheels aren't nearly as thick as aluminum wheels.
Old Jan 22, 2013 | 10:36 AM
4cylfiend's Avatar
Interesting. Post up a pic when you get it all mounted!
Old Jan 23, 2013 | 11:09 AM
i64X's Avatar
Got my D's on today. For anyone wanting to do the same thing, you can order part number BSP-WSG5L250 for the wheels and part number CRR-3425712P for the spacers from Summit Racing. My lug bolts are stock and there is PLENTY of room even after the spacers since the wheels are much thinner than aluminum wheels. I measured as best I could Crager wheel + spacer vs. the OEM wheels vs. the MB Motoring wheels that I had on the CRV in the pics above, and there was virtually no difference between them.
FYI for anyone who cares, the tires are 215/75/15 and I did not have to cut anything or grind on the calipers. I used OEM Honda lug nuts. Now that I think about it, in case Summit changes their part numbers - here are the specs of the spacers and the wheels:
SPACERS:
Brand:Billet Specialties
Manufacturer's Part Number:WSG5L250
Part Type:Wheel Spacers
Product Line:Billet Specialties Wheel Spacers
Summit Racing Part Number:BSP-WSG5L250
Thickness (in):0.250 in.
Thickness (mm):6.00mm
Center Bore Diameter (in):3.080 in.
Center Bore Diameter (mm):72.23mm
Lug Nuts Included:No
Lug Bolts Included:No
Wheel Studs Included:No
Wheel Spacer Material:Aluminum
Quantity: Sold individually.
WHEELS:
Brand:Cragar
Manufacturer's Part Number:3425712P
Part Type:Wheels
Product Line:Cragar Black D Window Wheels
Summit Racing Part Number:CRR-3425712P
Wheel Diameter:15 in.
Wheel Width (in):7.000 in.
Wheel Material:Steel
Primary Wheel Color:Black
Wheel Finish:Gloss
Manufacturers Wheel Series:Cragar D Window Series
Backspacing (in):4.250 in.
Offset:+6.00mm
Wheel Construction:2-piece
Beadlock Functional:No
Beadlock Included:No
Lug Nut Seat Style:Conical seat - 60 degree
Hub Centric:No
Center Bore Diameter (in):3.300 in.
Center Cap Included:No
Valve Stems Included:No
Quantity:Sold individually.
Wheel Bolt Pattern:5 x 4 1/2 in.
I also removed the stock mud flaps front and rear. Before anyone asks - no I'm not getting rid of them. I just took them off because they looked a little odd given the fact that the wheels/tires stick out further than the flaps did. :-)
I hope this information helps some people out. When I was researching how to make these wheels work I got a lot of conflicting information. One of the forum posts I read mentioned the same wheels and said "I would need a 1" spacer to even come close to making these work, so I took the wheels back." That was enough to scare me away from them the first time. At that time there wasn't a lot of people with this setup though, so I felt more comfortable going at it this time.
Even still, like I said, I hope this helps someone out who's searching. Anyway, enough with numbers - here are the wheels:
Back typically sits around 1/4-1/2" higher, but it's loaded down with a ton of stuff right now, including a jack, 4 stock wheels and tires, and the 4 MB wheels I took off. Still, I'm happy with it. :-) When my bug shield comes tomorrow I might install that and take some pics with a real camera.
Old Jan 23, 2013 | 11:28 AM
4cylfiend's Avatar
LOVE IT!!!!!!!!!!!!!!!!!!!
Old Jan 23, 2013 | 11:35 AM
i64X's Avatar
Thanks dude.
