Help with b16 problem......
b16 into my 91 si....put her in started her up no codes ran perfect for 50 miles or so
Today while accelerating the engine just stopped for a second then started back up(it was still in gear) it got worse and worse until I could no longer restart the car at all....
I know its getting spark its got fuel at the rail, there is no codes at all
I took out the injectors and cleaned them off with brake cleaner and put them back in. Changed the fuel filter also. All it does when I start it is back fire a little bit......
thanks for your help
[Modified by eraser, 10:51 PM 10/20/2002]
u got fuel and spark but no pow? try ecu, run a stock si and see she runs, also try a compression test or see if u jumped timing on a cam gear, to think of it check your valve train, all a motor needs is air spark and gas and it seems u got all of these so maybe they arent being used right? thats all i can think off good luck
[Modified by CRXSIFUEL, 2:40 AM 10/21/2002]
check your plug wires,, make sure there not in the wrong sequence, i know it sounds dumb, but ive done it. also check all your grounds. i had VTEC come on and off like 4 times through 3rd gear once,,,AKA a bad tranny to chassis ground.
does anyone else think it could be injectors? main relay?
also remember that this car RAN PERFECT for about 30 minutes
kc_kc
16
Dec 3, 2010 06:02 AM
egGSR_hi
May 16, 2009 12:23 PM
WWTeg
Mar 9, 2008 05:00 PM
sabertooth
23
Jun 21, 2004 08:21 AM
