Collector help
Old Jan 16, 2013 | 07:39 PM
boostedb20z's Avatar
Default Collector help
i know this has been covered before but i cant find the answer to my questions. ok so im trying to make some collectors 1 being a t4 open flange 4 into 1 ive tried different angles but whatever i do it just doesnt line on to the flange very well what is everyone doing to make them fit very nice its like it needs to be more square same on my t3 collector it fits very nice but i want it prefect whats everyone doing to make a round peg fit in a square hole lol thanks guys
Old Jan 16, 2013 | 08:44 PM
SovXietday's Avatar
Default Re: Collector help
Are you having issues with the collector itself or trying to get the collector to fit around a T4 and T3 flange?
If it's the latter, some cold working with a hammer and some sculpting will be involed, or you can just put it on there and port it to match.
Old Jan 17, 2013 | 03:27 AM
that-guy's Avatar
rather than wasting a bunch of expensive sch10 or 40, just buy one already tacked together from Verocious
http://www.verociousmotorsports.com/...rge-Collectors
Old Jan 17, 2013 | 04:10 AM
my collectors lines up really nice the problem is making it fit around the t3 and t4 opening in the flange. Its like it needs to be more square or rectangle for t4. I have cut them at 11.5 deg and up to about 16* or so i know the tighter the cut the squarer the collector and more of and angle will make it more round. these and all being cut using 4'' pieces. thanks for the help
That-Guy ordering a premade one takes the fun out of fabrication work thats like saying why not have a robot weld it cause im not consistent enough lol
edit- took some pics
t4 flange
T3 flange not that bad
Old Jan 17, 2013 | 06:25 AM
that-guy's Avatar
i understand that...besides, their collectors are only tacked so you can fully weld them yourself...anyways, can you cut more off the bottom, or is the point of intersection in the center of the collector too close as it is? most of the time you just need to cut off the excess until it is slightly larger than the opening of the turbo flange
from what i see, you built your collector properly for a T3, but you need to use 2 different angled cuts for a T4 to make more of a rectangle at the base of the collector
Old Jan 17, 2013 | 08:47 AM
Ya I agree with the t3 one just needs trimmed down and it would line up pretty good but it still kinda runs into the flange blocking air flow to turbo I can port some but don't want have to port a lot off the flange. Ok back to the t4 I've tried different angles but what do u mean by 2 different angles?? I'm going to try and say what I think u mean bear with me.
Ok so there's 2 cuts on each pipe 90 or so apart so your saying make the ghost cut then rotate 90 or so and change the angle from let's say 11*for the frist cut to 15* and make second cut and do that on all 4?? Or Ian I just making crazy crap up lol thanks again
Old Jan 18, 2013 | 01:38 PM
Bump
Old Jan 22, 2013 | 01:07 PM
vtechjunkie's Avatar
I think "snowtrooper" or someone has an entire write-up on collector building.........Might be another member though.
Old Jan 22, 2013 | 02:02 PM
all_motor_mike's Avatar
all 4 of the individual tubes cant have equal cuts on both sides..... the first cut needs to have less taken away from it vs the second cut on 2 of them and visa versa on the other 2 so they are a mirror image of each other. i can do it but its a pita so i oustource for my collectors now... its just easier. i buy them tacked, mount the flange how i need it and do all the welding myself. no shame there imo.
mike
Old Jan 22, 2013 | 02:35 PM
mike after talking with u on here i made a t4 collector the way u just said last weekend turned out great im just starting to fab a wanted to know how to do it incase i have to make one most likely ill outsourse them in the future where do u get yours from ?? i am very **** on the quality of how they line up too mine are 100%
Old Jan 22, 2013 | 03:07 PM
Walterronny's Avatar
i will try to design it in about 30 min, im practicing for make perfect collectors too, just trying first with cad.. ill let you know
Old Jan 22, 2013 | 03:35 PM
i use to get them from sls but now i get them from a different place. they normally dont just sell the collactors but they help me out so i dont want to throw their name out on here if u get where im coming from.
but if i had to go some place else it would be .....
http://www.bmcrace.com/4-to-1/4-to-1-products_c43p1.php
mike
Old Jan 22, 2013 | 03:44 PM
it's not perfect but...
just with slight modifications should fits perfect!
i will check what angles will be used for make this.
Old Jan 22, 2013 | 04:13 PM
didnt know why first time looked that.. this is how it should looks like. cuts will be 13.88º - 92-94º rolling over.
you can see inside fits good
This is what i got on cad, i hope this help.
Old Jan 22, 2013 | 04:14 PM
btw, pipe used was sch10 1.5" (48.26mm OD)
Old Jan 22, 2013 | 06:00 PM
lopez286's Avatar
good info
Old Jan 25, 2013 | 04:16 PM
Thanks!
LKSi
Welding / Fabrication
Apr 24, 2015 06:05 AM
got wide
Aug 2, 2007 01:39 PM
TurboSI56
Sep 14, 2006 09:29 PM
