CRX DX/D16a6 cranks but doesn't start after mpfi conversion...
So I pulled my d16a6 out of my crx si and dropped it in my crx dx.got a dx harness converted and just wired everything up hopefully right but mayb not cus car cranks but dsnt start.wat can b the problem.?the engine was running fine and always turned on on the first crank.plz help
first doublecheck your wiring tp your distributor. Just for ***** n gigs spray some starting fluid into the throttle body. If your lucky enough it might start or puke a couple of times just enough to throw a code. that will help you pinpoint the issue a little better. If nothing happens with the starting fluid then you definately dont have spark...it would be a wiring issue.
mengy007
30
Oct 4, 2006 06:55 AM
BIG RICH
Sep 16, 2006 11:55 AM
2ndGenREX
May 27, 2003 06:22 PM
