Stopped pressed clutch and car stalled
Old Jan 15, 2013 | 03:35 PM
new_climber's Avatar
Default Stopped pressed clutch and car stalled
To while at lunch, I stopped at a red light, had it in first gear with the clutch pressed in...all of a sudden, the engine stalled or wanted to stall as if I didn't have the clutch pressed, still in gear but came to a stop...
Popped it out of gear and then had a very hard time getting it back into gear. All of a sudden, it popped into gear and no other problems..until I got back to work..and again the same think....
Someone mentioned I have a leak in the master or slave. I looked real quick and didn't see anything leaking, and it didn't look like I was low on fluid. But the o-ring at the top of my master cylinder (the cap where you add fluid) is pretty beat up.
Any ideas on what to check or what could be the issue?? The clutch petal doesn't feel soft or anything...
Old Jan 15, 2013 | 04:30 PM
Emeraldbomber's Avatar
Default Re: Stopped pressed clutch and car stalled
You answered your own question. Check your master cylinder and make sure your slave is pushing your fork correctly.
Old Jan 15, 2013 | 04:43 PM
weavertime1's Avatar
Check the clutch master cylinder for a leak inside of the car where the rod comes out of the rubber seal.
Old Jan 16, 2013 | 08:31 AM
Thanks much guys...I will check that out today...
One questions....would I expect to have a "soft" clutch pedal if I am leaking?
Old Jan 16, 2013 | 09:01 AM
It could get softer yes. Does the pedal spring back up quickly when you let off?
Old Jan 17, 2013 | 12:39 PM
Well, I found the master cylinder leaking when I looked under the steering wheel area on the floor board. so i went ahead and replaced the master cylinder...
But
Now I have to almost press the clutch to the floor to get it to disengage. I have adjusted the pedal/cylinder position to it's max, meaning the threads are about the come off the coupler.
Is there something else I am missing that I can adjust? Tonight when I get home, I am going to try and bleed the clutch system again at the slave cylinder..but besides that, any ideas?
Old Jan 17, 2013 | 12:49 PM
pityocamptes's Avatar
Sounds like you need to bleed it...
Old Jan 17, 2013 | 02:49 PM
Quick questions....do I leave the reservoir open...or fill it and close and put the cap on it? I was not sure if the cap was off, if the fluid would shot out?
Old Jan 17, 2013 | 02:56 PM
kwong2001's Avatar
Leave the cap off, it's fine. Just make sure that you don't run the reservoir dry while bleeding. Otherwise you have to start all over.
Old Jan 17, 2013 | 05:45 PM
Also when you bleed it I find it is best to pump it with your hand that way you can pump it quicker...Ok so that sounded bad, but I promise it works better that way. Sometimes bleeding a clutch can be a pita!
Old Jan 17, 2013 | 10:18 PM
hwyix's Avatar
You might get lucky and be done in 20 minutes or you might be there all day.
Rootie524
Transmission & Drivetrain
Sep 13, 2013 09:26 AM
mouab18c1
Oct 21, 2009 10:07 PM
jwshilli
Jul 14, 2009 03:02 PM
Luchini
Oct 16, 2005 11:15 AM
herbalist
Mar 25, 2005 07:59 PM
