Low idle/Sputter
Hey guys, I have a b16 Crx(DC header, CAI, exhaust, and a chipped ECU, removed all the dashpots) And whenever I start my car from a cold start it idles low at around 800 rpms(for a split second) then drops to around 500. If I push on the gas it hesitates/sputters(almost sounding like backfiring but it's not), then jumps up, then shoots way down to about 200-300 rpms, then goes back to 500 rpms. If I leave it alone for awhile at 500 rpms,then turn the car off and on, it returns to the normal 1000-1200 rpms and doesn't sputter/hesitate. I am thinking it could be the ECU just dumping fuel as the program is pretty bad( you can smell fuel from pretty far away) and I don't have another OBD0 ECU to test. I do have a check engine light.Any idea's? Thanks.
