Intake tests on the RSX-S
Old Oct 20, 2002 | 02:16 PM
typer.org's Avatar
Default Intake tests on the RSX-S
I know it isn't the Type R that they did the tests on, but has anyone read the article? I can't remember what mag it was in, but they did tests with the stock intake, stock with K & N filter, DC short ram, DC CAI, jackson racing, AEM CAI, etc, etc, etc.
Both the cold air intakes made 20+hp over stock and 5.5+ torque over stock where as all the other short ram intakes made at the most 10+hp and not as much torque gain.
I guess my question is after this why wouldn't everyone change from a short ram to a cold air intake after seeing something like that?
I've had the AEM CAI and I know the throttle response isn't as good, but with hp numbers twice as good (on a RSX-S) the throttle response isn't that bad.
I do know that the numbers wouldn't be so huge on the ITR, but the RSX-S isn't a car that comes with just **** on it.
After reading the article I'm glad I got the CAI and not a short ram......
I guess I just want to know if the J's Racing intake is all that? Yes it's pretty, but is it going to give the numbers of a CAI?
[Modified by love4baseball, 6:17 PM 10/20/2002]
Old Oct 20, 2002 | 02:17 PM
Rob :190:'s Avatar
Default Re: Intake tests on the RSX-S (love4baseball)
wait, so all that and you're just asking about the J's intake? try the search, theres a bunch of info recently...
Old Oct 20, 2002 | 02:18 PM
typer.org's Avatar
Default Re: Intake tests on the RSX-S (Rob :190:)
no not just the J's. I've read all the posts. It was just kind of a broad open question for people to throw out some oppinions. Not the try the search one either.
I've seen that one plenty of times.
Old Oct 20, 2002 | 02:23 PM
typer.org's Avatar
pretty much I want to see if anyone has a reason to get anything other than a CAI. Not including the possible water damage.
Old Oct 20, 2002 | 02:28 PM
2001TypeR's Avatar
apparentyl the reason it gained so much id buc when they dynoed it they reset the ecu for the basline run and Don't break it in or let it "learn", then for the intake run they reset it for the intake and let it learn first...
Old Oct 20, 2002 | 02:34 PM
disordeR's Avatar
Default Re: Intake tests on the RSX-S (2001TypeR)
you did not read all the posts because your questions WOULD have been answered.
the J's will most definitely NOT produce numbers like the CAI. you'll lose some/a little(i don't know how much for fact), but the biggest plus about the J's is the throttle response which was posted in practically EVERY J's racing intake thread on this board.
throttle response. period.
Old Oct 20, 2002 | 02:37 PM
typer.org's Avatar
Default Re: Intake tests on the RSX-S (disordeR)
will the throttle response make up for the higher hp and torque numbers?
how much is the throttle response worth?
are we talking 1/1000 of a second difference?
1 foot off the start?
I know it makes a difference, but then what about the 10 feet you gain after 2 1/2 or 3 gears?
I'm not saying anyone is right or wrong just want to see what other people value more?
I've been looking for dyno stuff with stock, CAI, and J's, but haven't seen anything yet.
Old Oct 20, 2002 | 02:41 PM
Dr Pooface's Avatar
You cannot compare that dyno test to ITR's. On a ITR the AEM makes AT THE MOST 10hp. If the js only makes 5hp that difference is negledgable.
Old Oct 20, 2002 | 02:42 PM
MK Ultra's Avatar
Bah. Intakes are snake oil.
The reason the RSX-S saw such a jump in power with a CAI is that the position of the stock intake on those cars really sucks. It's not possible to get cool air to that location easily. As far as I know, all of the CAI intakes for the RSX require you to relocate things (like the battery) so they'll fit.
On the ITR it's a different story. The stock intake draws cold air and is farther from the engine. Stock intake + K&N is all you need IMO.
[Modified by MK Ultra, 5:43 PM 10/20/2002]
Old Oct 20, 2002 | 02:55 PM
4-1-1's Avatar
Default Re: Intake tests on the RSX-S (MK Ultra)
I was looking at the K20A2 engine the other day and the engine bay is so damn small.........
Old Oct 20, 2002 | 03:18 PM
Rob :190:'s Avatar
Default Re: Intake tests on the RSX-S (4-1-1)
we've had enough intake threads to choke the Mississippi. get what you want, what you can afford.....if you have to ask if the throttle response is worth it, i dont think you will notice....
Old Oct 20, 2002 | 03:49 PM
typer.org's Avatar
I've already got what I want, but I figured people who have run their car stock, CAI, and short ram (possibely J's) could throw out some answers like, "I like this, but dont like that abou this one, etc, etc, etc"
I do know people who don't know what they want and would like to know if that RSX-S test is somewhat comparable to the R.
It would be sweet if everytime you were thinking about getting a mod you could put 5 different types of that mod on your car and do tests, but you can't so you have to read different things to figure it out. I had just read an article and all the J's stuff with the throttle response or lack of it (CAI) and wanted to see what people here had to say.
Thanks!
Old Oct 20, 2002 | 03:55 PM
B2FiNiTY's Avatar
I have posted what I like about each and I will do so again.
AEM CAI - Good spike midrange, then dips and some more 7k+ rpm gains. Sorry throttle response
J's Racing - Power is smooth and linear, no spikes, less power made than the AEM CAI. Floor and Go.
[Modified by ExOdy, 4:55 PM 10/20/2002]
Old Oct 20, 2002 | 04:01 PM
disordeR's Avatar
throttle response makes a big difference in auto-cross and road racing. you want straight line? cai.
Old Oct 20, 2002 | 04:24 PM
Eric R's Avatar
I tell you what I like: Drop in Comptech Foam Air Filter and Modified Stock Airbox with ram air duct. Works marbels!
[Modified by Tweety R, 5:26 PM 10/20/2002]
imaginAZN
Oct 15, 2006 09:41 AM
Accord6Gen
Oct 1, 2004 02:57 AM
kseriesDC5
Feb 27, 2004 08:57 PM
binkster
Oct 29, 2003 05:05 AM
Skunk_it
Oct 6, 2002 11:56 AM
