b16a2 swap turning off. PLEASE HELP!
Old Jan 14, 2013 | 04:24 PM
red ekrandy's Avatar
Default b16a2 swap turning off. PLEASE HELP!
So I got the swap to finally start today!! but now the problem is when i try to get it some gas it just bogs and dies on me.
Anyone know what is wrong? and what i need to do to fix it.
please help!
thank you!
Old Jan 14, 2013 | 05:34 PM
Former User's Avatar
Default Re: b16a2 swap turning off. PLEASE HELP!
Start by giving some useful details about your swap.
Any CEL codes?
Old Jan 14, 2013 | 10:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Well, without any more details than what you provided... I can only suggest swapping your TPS and MAP sensor plugs and try again. If no change, and you still cannot depress the gas pedal without the engine stalling, switch them back and bring us more details please.
Old Jan 17, 2013 | 06:17 AM
I have swapped the TPS and the MAP sensor and i didn't want to turn on, my timing is good, I'm getting fuel, I have checked all my ground cables and they are good.
I don't know what else to check. i haven't checked the CEL yet, I'll get it check by this week.
Old Jan 17, 2013 | 06:23 AM
JuggerNaut-CTR's Avatar
Thats a pretty useful thing to check...will probably narrow it down for you
Old Jan 17, 2013 | 07:11 AM
Please read the Rules sticky at the top.
What car?
What ECU?
What wire harnesses?
etc.
Old Jan 17, 2013 | 08:18 AM
What car?
What ECU?
etc.
98 Honda civic hatch back cx
I pulled the b16 bswap from a 90 integra
My car didn't start when i was using the p28 with a jumper harness
it started when i use the stock y7 ecu
later today i'm going to try a type r ecu p73 to see if that would change anything.
I am using the stock harness from my single cam motor i modified the IACV to 3 wire to 2. That all i did to the harness.
I also think the dizzy is obd1 I'm not so sure about that. I have a conversion harness for that too. 2 plugs to 1 plug
EJ-1
20
Nov 17, 2012 09:04 AM
blowoutj00si
Dec 15, 2008 01:46 PM
Nfire247
13
Aug 4, 2007 08:35 PM
FLIPboi
Aug 29, 2002 07:16 PM
