98 Type-R swap wont start- Epic issue-OG's please help!
Old Jan 14, 2013 | 12:53 PM
1stgenboost's Avatar
Icon3 98 Type-R swap wont start- Epic issue-OG's please help!
Ok thanks for viewing this thread I have tried everything I can think of and done any and all research before posting this so bare with me.
The car is a 98 GSR with 98+spec ITR swap 45k miles has started and ran fine for the past year. Drove it to the store came out it wouldn't start.
Issue- Shooting fuel from intake, solid check engine light, no spark, wont start.
When I prime the key it seems as tho the injectors are staying open, when I pull the plugs and the key is primed I can hear it spraying and see mist coming out of the spark plug chamber (doesn't stop) until I turn the key off. Seems like alot of fuel for the short amount of time the key is on.
I inspected and replaced the distributer with a known working one from a friends car still wont start. The car does have a solid check engine light so my next assumption is ECU. So I order a chipped and socketed obd-1 ecu and jumper harness. I install and it stayed the same issues, solid light no spark no fire. I grabbed a friends obd-1 LS ECU after that and tossed it in (didn't try to start it) I.E different maps, did not wanna hurt it but it DID have spark.
I just went today and purchased a stock obd-2 JDM type-R ECU and put it in and still the same issue, no spark, dumping fuel, wont start, solid cel.
I have checked every fuse under the dash and under the hood and everything checks out fine. I have checked all grounds and they seem fine as well. I have called several Honda/Acura performance shops in the area and none of them seem to have a clue much like myself so any and all insight is greatly appreciated. This car is my DD and it is ******* me over massivly by not being able to drive PLEASE HELP!
Old Jan 14, 2013 | 01:06 PM
Aquafina's Avatar
Default Re: 98 Type-R swap wont start- Epic issue-OG's please help!
This belongs in the hybrid or Integra forum.
Most of the OG's don't post anymore.
Old Jan 14, 2013 | 01:26 PM
Well that sucks to know... I also just got a bit more insight on the issue, apparantly before the car turned off there was a surge in idle. It went from 1k-2k fluctuating. Now I am leaning towards crankshaft sensor. I jumped the pins and the CEL stayed solid but the ABS light blinked out three codes I am not sure if it is blinking me CEL codes or ABS codes but if it is CEL I am getting a TPS,CYP, and Traction control. I am going to replace the crankshaft sensor and see if that does the trick.
Old Jan 14, 2013 | 04:12 PM
c5stunna's Avatar
Id try changing the map sensor. but first if your friend has a WORKING throttle body with 98 sensors just swap it over to save you some money. Be careful you dont break the throttle body gasket or you will have to buy a new one.
if that doesnt do it my only other guess without checking it out in person would be the main relay?
Old Jan 14, 2013 | 04:13 PM
pennies_hatchie's Avatar
Cels will be flashing from the check engine light. Check your distributor if there's no spark.
Old Jan 15, 2013 | 04:26 PM
Well update,turns out it is and obd1 engine so there is no crank sensor. I did notice it was off one tooth in time but I highly doubt that was the issue. Kinda back to the drawing board..
Old Jan 15, 2013 | 04:27 PM
Distributor is perfect by the way as I mentioned in the opening post.
Old Jan 15, 2013 | 04:41 PM
whitelightning's Avatar
Taking a stab at it.... Have you checked the igniter?
Old Jan 15, 2013 | 06:44 PM
jru124's Avatar
Check your fuel pump connector under your backseat lower cushion. If its corroded its frying your ecu,causing the injectors to stay on. U need to repair the wires before u put another ecu in. Hope this helps
Old Jan 15, 2013 | 06:46 PM
jru124's Avatar
If its corroded,u got a water leak
Old Jan 16, 2013 | 10:29 AM
You sir are a God damn gentleman and a scholar lol. I pulled the back seat and sure enoughthe connector was submerged in water and covered in corrosion. One wire even came free from the plug. I'm off to buy a new plug as we speak ill post the results!
Old Jan 16, 2013 | 01:04 PM
Ok update, I hard wired the connectors but now I am still expieriencing a solid check engine light and I don't hear the fuel pump prime at all. I have tried three different ECU's but I did try them all before I hard wired it so I suppose they could all be fried. Kinda at a loss for words at the moment. My guess is I need to try and find a known working ECU and try that. I'm not hearing the main relay do anything and im not hearing the fuel pump prime.
Old Jan 16, 2013 | 01:15 PM
Does anyone have a schematic for the connector coming off the pump by chance?
Old Jan 16, 2013 | 02:10 PM
jru124's Avatar
Do u still have the old connectors with some wires on it? u can match up the wire color from one end of the connector to the other end. Sounds like u got the wires mixed up,bad crimp,or blew a fuse? Look at one of your friends integra harness n match the wires. Hope this helps
Civek
10
Aug 26, 2015 08:45 PM
EKcpe00
Nov 14, 2010 02:27 PM
97_delsol_Vtec
May 4, 2007 04:28 PM
4CDFED
Aug 13, 2006 12:11 PM
JDM97R
Jan 6, 2004 10:06 AM
