Clutch noise when in neutral and the pedal is not pressed down
Old Jan 14, 2013 | 08:44 AM
Root16's Avatar
Default Clutch noise when in neutral and the pedal is not pressed down
sort of a "gghhhh" kind of noise. It seems to only do it when the engine isn't yet up to operating temp.
Makes the noise when the foot is off the pedal as indicated in the video.
The video was taken when the car was in neutral and not moving; shortly after starting it after it had sat for 48+ hours.
Old Jan 14, 2013 | 08:53 AM
TypeRfit's Avatar
RESIDENT
Default Re: Clutch noise when clutch NOT engaged
Throw out bearing
Old Jan 14, 2013 | 08:57 AM
PerfectionIsKey's Avatar
Originally Posted by typerfit
Throw out bearing
I think mine does the same. Is that the only effects that a throw out bearing causes? Or are than any other obvious ones.
Old Jan 14, 2013 | 10:15 AM
Former User's Avatar
The noise happens when the pedal is up not down, right?
If so, a bad transmission main bearing, typically for the input shaft, is the likely cause.
(The clutch is engaged with the pedal up)
Old Jan 14, 2013 | 10:21 AM
Crashmaster91's Avatar
Mine has that noise when I let off of the pedal. Almost sounds like the clutch wants to grab or something. I planned on replacing the whole clutch set up this weekend. Clutch, pressure plate and throwout bearing. If I get it done, I'll let you know if it fixed the problem.
Old Jan 14, 2013 | 10:23 AM
Old Jan 14, 2013 | 10:33 AM
Root16's Avatar
The video was taken (ie, the symptom I speak of) happens when the car is in neutral and not moving. Yes, when the clutch is engaged by your definition (but it's not in gear, so is it accurate to say the clutch is engaged?). If I could edit the title of my post I would change it to: Clutch noise when in neutral and the pedal is not pressed down.
Old Jan 14, 2013 | 10:38 AM
This^ points to a bad transmission main bearing, not a bad clutch throw out bearing.
I edited the title for you.
Old Jan 14, 2013 | 11:01 AM
Root16's Avatar
Default Re: Clutch noise when in neutral and the pedal is not pressed down
Thanks! That sound expensive. How long can I drive it like this without .. I dunno.. something bad happening? What is my recourse?
Old Jan 14, 2013 | 11:05 AM
Transmission main bearings can be replaced. It's the input shaft bearing that usually fails. The cost is minimal if you can and are willing to do the work yourself. Check the FAQs sticky.
Old Jan 14, 2013 | 11:31 AM
Root16's Avatar
Right. Well, I won't be doing that anytime soon, but thanks for the link! What's the prognosis if I keep driving the car without tending to it?
Old Jan 14, 2013 | 11:34 AM
Breakdown at an inopportune time. Eventual possible destruction of transmission, clutch, and flywheel.
Old Jan 15, 2013 | 03:32 AM
ameer_vtec99's Avatar
hi cheake maybe it bcuz the release bearing in your gear
Old Jan 15, 2013 | 03:53 AM
Root16's Avatar
Hmm? I don't understand what you said. edit: I think you mean you think the sound maybe is caused by the release bearing in my gear?
Just another added piece of info: when the engine is warm and in neutral and clutch engaged, it sounds like a fan is on and the sound isn't as loud/noticeable as when the engine is cold. Thanks again for all the help.
shermanyang
Dec 1, 2012 11:24 AM
93accordEX
Feb 2, 2010 04:40 AM
HondaMan_TypeR
14
Jan 6, 2009 05:21 PM
rdssk8rcs1
Jul 23, 2008 08:00 AM
JDMtype Eg6
May 29, 2006 03:45 AM
