Installed F&F1 Coilovers = Car Vibrates
Old Jan 14, 2013 | 04:06 AM
305civictyperaw's Avatar
Icon2 Installed F&F1 Coilovers = Car Vibrates
Need some input H-T'ers.
I just installed Function&Form Type 1 Coilovers on my 98' Coupe yesterday and for some reason car starts shaking when taking off from 1k-4k RPM.
The car was on ebay coils before with stock struts but it wasnt as low as i am now (Didnt vibrate).
I replaced both axles, and made sure all bolts were tight and it kind of seized the vibrations at high speeds but it still shakes at low speeds. I'm thinking i might need new Motor mounts?
What should i check next?
Old Jan 14, 2013 | 04:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Installed F&F1 Coilovers = Car Vibrates
Alignment.
Old Jan 14, 2013 | 04:49 AM
Originally Posted by grumblemarc
Alignment.
this would mean i need front & rear camber kits prior to getting it aligned right?
Old Jan 14, 2013 | 04:55 AM
TypeRfit's Avatar
RESIDENT
Not necessarily, camber kits don't fix toe issues. If your toe is set correctly camber will not ruin you tires
Old Jan 14, 2013 | 04:59 AM
Makes sense. thanks guys ill look into an alignment
GoLowDrew
Suspension & Brakes
Jun 6, 2015 04:46 PM
Yonick90
Sep 23, 2009 11:16 AM
bow tie
Suspension & Brakes
Jun 12, 2006 08:17 AM
Stunna MIKE
Sep 15, 2005 07:03 AM
PorscheGT2
Mar 12, 2002 08:18 PM
