2000 prelude brake lights
Old Jan 13, 2013 | 07:18 PM
herlude's Avatar
Default 2000 prelude brake lights
when i press the brake pedal my 3 rd brake light comes on but not the brake lights in the taillights, i replaced the bulbs and still nothing. fuse appeaers to be good and i assume that the brake light switch is good since the 3 rd brake light comes on. also any ideas on how to stop water from leaking in around the tail lights. thanks for any help
Old Jan 15, 2013 | 08:28 PM
go-part's Avatar
Default Re: 2000 prelude brake lights
Test and make sure power is coming through the wires to the bulbs.
Weatherstripping would keep the water from getting into the light housing
Old Jan 20, 2013 | 10:56 AM
Qluder's Avatar
Change the taillight gaskets. Common problem and an easy fix. Visually inspect the sockets and perform a voltage check. If they are corroded, they may need cleaning or replacement
Check the wiring diagrams in the service manual for your year and model. You may have a wiring or ground issue, especially if you've had water in the trunk from the leaky gaskets.
nicolaselias
Dec 22, 2011 03:58 PM
Egpower88
Nov 5, 2009 01:12 PM
AndyD
Feb 18, 2008 11:09 PM
chronic4dr
Sep 9, 2005 09:51 AM
gejuhaszvti
Aug 11, 2004 11:18 PM
