'88 civic stays on without the key?!
Old Jan 13, 2013 | 03:04 PM
xaviACCORD's Avatar
Default '88 civic stays on without the key?!
I bought a civic hatchback not too long ago and im thinking that i need a new ignition switch to stop the car from staying on when the key is pulled out in the off position. It starts right up fine. I can here the clicking in the ignition and it moves like it should when the key is in the key hole. I heard it could also be due to a loose ground or relay but am not completey sure. If it is due to a relay is there some sort of ignition relay and does anyone know the location of it, or do i just need a new ignition switch?? Thanks.
Old Jan 13, 2013 | 03:08 PM
scarney's Avatar
Default Re: '88 civic stays on without the key?!
Switch
Old Jan 15, 2013 | 11:08 AM
xaviACCORD's Avatar
I replaced the ignition switch and it did not sole the problem. What the hell could it be?!
Old Jan 15, 2013 | 12:18 PM
accord_2dr's Avatar
I think it is the key cylinder. When you insert the key is it pretty firm or does the key have some play?
Old Jan 15, 2013 | 05:57 PM
xaviACCORD's Avatar
No it didnt have any play....but i found out what it was lol it was this jerry rigged wire connected to a fuse under the dash!! i still havent followed the wire to see what it is yet. At least the car turns off with the key now!! Thanks
Barf Hat
Oct 9, 2019 05:45 AM
rizzuto_usmc
Oct 21, 2013 12:30 AM
BigDaddyRich
Mar 31, 2005 04:42 PM
91hob20hb
Jul 17, 2004 11:16 AM
JToolz
Feb 15, 2004 06:56 PM
