s4c ctr trans issue
s4c helical lsd ctr trans:
i have a 6 puck clutch sprung stock b series pressure plate and flywheel
my issue is when i am driving and from time to time i go into third and it will push it out... and other times it will go in smooth no issues.... and also in morning time when i start driving i go into third it will kick me out instantly... and at high rev i can go to scond or third but if i am at high rev and i baby it in will go in no issue...
hope i explained it right...
could it be stock pressure plate???
could it be bad syncros?
info and input would be awsome thanks
thats not from the clutch at all
your right that is going to be syncro's
time to put a full rebuild kit through it
" Bearings Syncro's Seals"
and you might want to think about an LS 5th gear while your in there
to lower your revs in top while cruising
Im about to do the same thing as my input bearing is going out
Synchro spring, dog teeth, slider teeth, shift fork (contact or detent), SCA, SCHA, clutch/pressure plate, CMC, CSC, etc.
What all have you checked so far on it?
lol just the pressure plate shift linkage trans oil bushings thats it right now... havent pulled it aprt yet.. but i will
H22ACiViC
Mar 16, 2002 04:12 PM
