b16a slight oil leaks
Old Jan 13, 2013 | 12:31 AM
Justef Datshiet's Avatar
Default b16a slight oil leaks
there been leaking going on my car and i cant seem to find it. it will be oil splat on the valve cover in the middle there my sparkplug wires are
for example;
and in the bottom left corner where its in between the cylinder head and block.
for example;
and it will be leaking right on my tranny
does anyone knows how to properly stop these leaks?!?!?!?!?!
Old Jan 13, 2013 | 07:58 AM
Former User's Avatar
Default Re: b16a slight oil leaks
Pic 1 --> replace the rubber washers/seals on the valve cover bolts. Any oil inside the spark plug tubes?
Pic 2 --> replace the distributor O-ring and VTEC solenoid gaskets. Any oil inside of distributor?
Old Jan 13, 2013 | 10:04 AM
in pic 1 you see one bolt in the middle where the parkplug wires are broken. how do u replace that one bolt?
no oil inside the distributor, so do i still have to replace the -o-ring gasket?
Old Jan 13, 2013 | 11:01 AM
Remove valve cover and bolt and then replace the bolt's rubber seal.
Yes, you should still replace the O-ring and VTEC solenoid gaskets.
If there were oil inside the distributor, then you'd also need to replace the internal oil seal in the distributor.
Old Jan 14, 2013 | 05:09 AM
no oil on the spark plug tubes. so should i just replace the O-ring and VTEC solenoid gaskets? and where is that o-ring gasket located?
mtg
11
Sep 27, 2010 08:11 PM
KillianJ
Sep 7, 2009 08:04 AM
Flatland2D
May 7, 2007 08:04 PM
jam36a
Aug 19, 2006 09:56 AM
Ghostyman
Nov 1, 2005 12:31 PM
