97 civic/b16a3 swap - P0135 code will not erase
Old Jan 12, 2013 | 10:44 PM
ehansford22's Avatar
Default 97 civic/b16a3 swap - P0135 code will not erase
Ok I'm tired of searching and trying everything possible to get this code gone so i can get my ny state inspection. I have a b16a3 in a converted auto to manual 1997 civic hatch. I've had 5 cel codes. Speed sensor. The intake sensor. Secondary and primary o2 sensors and the ckf sensor. I am down to this pain in the *** primary. So far I've replaced the o2. Thought driving 60 miles or so would clear the code. Didn't work so tonight 1/12/13 I've wired my o2 exactly to my Ecu. I am running a obd2 p72 GSR Ecu. The only things I can think of is a faulty Ecu or to much air flow due to my aftermarket header. PLEASEEE helps. My wiring is correct. O2 is brand new. Fuse 15 is not blown. Looking forward to some advice!!!!!
Old Jan 12, 2013 | 11:07 PM
Default Re: 97 civic b16 po135 code will not erase
36 views and no responses. Need some help please!!!!
Old Jan 13, 2013 | 02:03 AM
jbpnoman's Avatar
Did you try actually resetting the ECU? You haven't mentioned that. Disconnect the battery, try to start the car (no, it won't start, but it clears out the residual power), reconnect the battery, and see if the code comes back.
Old Jan 13, 2013 | 08:04 AM
Former User's Avatar
Check whether 7.5A dash fuse 15 is blown by voltage testing it installed. Both test tabs should have battery voltage with the key in ON(II).
At the unplugged O2 sensor connector, resistance test the heater element of the "new" primary O2 sensor. It should read 10-40 Ohms.
Test whether the heater element power wire at the unplugged O2 sensor connector (wire harness side) gets battery voltage and also whether the heater element ground wire has continuity to body ground.
Old Jan 13, 2013 | 10:17 AM
Yes sorry disconnect battery for an entire day. No luck, used the obd scan tool to clear it also. It's off for about 3 seconds then comes right back
Old Jan 13, 2013 | 10:22 AM
Racer02gtstang's Avatar
If it comes right back there is a issue somewhere in the heater circuit
Old Jan 13, 2013 | 10:24 AM
Both tabs have power on fuse 15. Wire harness side plug has battery voltage. Will try the resistance test and continuity ground test. Thanks for the help. You don't think it has anything to do with a defouler issue right.i was gonna try that today and see if it was the exhaust flow messing with the o2?
Old Jan 13, 2013 | 10:25 AM
So could it be the o2 Ecu or the wiring I've just done directly to the Ecu?
Old Jan 13, 2013 | 10:27 AM
No. It's an electrical issue in the heater circuit of the primary O2 sensor. If the element Ohms out good and gets voltage, then test the element ground wire.
Old Jan 13, 2013 | 10:34 AM
Ok will try this as soon as I can. Thank you for the help guys. Once I try I will come back to my post with updates!!
Old Jan 13, 2013 | 11:50 AM
Ok I was trying to look up on how to test Resistance for the unplugged o2 and the continuity for the heater ground. I have a digital multi reader. Is that what I use and could you give a little detail on how to check them. I'd really appreciate it!
Old Jan 13, 2013 | 11:59 AM
A digital multimeter is exactly what you need.
Testing ground wire
The heater element ground wire is Blk/Wht.
Unplug the O2 sensor connector.
Turn key to ON(II).
If the meter has a continuity test setting (makes sound if there is continuity), use it for the test
Touch one meter probe to the Blk/Wht wire terminal and one probe to the transmission or engine. You should hear the meter sound.
Do you know how to test for voltage?
Old Jan 13, 2013 | 12:30 PM
Testing ground wire
Turn key to ON(II).
That sounds easy enough. And I was looking but if you could knowledge me with the how to on voltage I'd appreciate that to. Thank you
Old Jan 13, 2013 | 01:18 PM
Testing voltage on O2 sensor heater power wire
The heater element power wire is Blk/Yel.
Turn key to ON(II).
Set meter to read DC volts.
Touch red meter probe to the Blk/Yel wire terminal and black meter probe to the transmission or engine. You should read a voltage similar to the reading across the two battery posts.
Old Jan 13, 2013 | 02:13 PM
Turn key to ON(II).
Ok thank you. I will try in a few minutes and give an update!
Old Jan 13, 2013 | 06:00 PM
Testing ground wire
Turn key to ON(II).
So I tried testing the unplugged o2. It kept getting a reading of OL which means over load right ? Is it possible this could have blew a fuse in my meter. It has stopped working after I got a couple of readings like that
Old Jan 13, 2013 | 06:04 PM
This means the ground wire is broken or the ECU is not providing ground. This is the problem. Test continuity of the ground wire between the O2 sensor and ECU plugs. if you touched the meter probes together, what is the reading?
Does the plug get voltage on the power wire?
Old Jan 13, 2013 | 06:13 PM
When I touched them together I got a reading of about .04 the meter stopped working. I think I might have popped the fuses in the back of my multi meter
Old Jan 13, 2013 | 06:14 PM
So you no longer get an Ohm reading when you touch the two probes together? If not, you may need to replace the battery in the multimeter.
Old Jan 13, 2013 | 06:43 PM
I no longer have the multimeter working. It will not turn on. I have changed the battery's in it and it still will not turn. Do you think anything could have happened to it from taking the readings. There are two fuses in the back of the meter. I'm thinking they popped?
Old Jan 13, 2013 | 07:18 PM
Open the meter up and check for a blown fuse. Otherwise, get your hands on another multimeter.
Old Jan 13, 2013 | 09:35 PM
I believe they are blown. Fuses are the small cylinder looking ones. Both glass pieces are white. Can not see through them at all so I'm guessing there shot. Will be replacing the fuses tomorrow after work. And getting back to the Honda. Will have an update tomorrow. Thanks again for the help!!
Old Jan 14, 2013 | 08:44 AM
I'm an idiot. I misread and thought you said to check the wires on the actual o2 sensor (non harness side) I'm suppose to be checking the harness side for resistance and continuity correct? The black/white and black/yellow?
Old Jan 14, 2013 | 09:18 AM
The resistance test of the heater element is done on the O2 sensor-side of the unplugged O2 sensor connectors.
The voltage and ground tests are done on the wire harness-side of the unplugged O2 sensor connectors.
Old Jan 14, 2013 | 10:09 AM
Ok thanks for clearing that up for me. Almost out of work. Will be stopping by radio shack for the fuses then going home to test them
