Honda CR-V & Element 2WD & 4WD Element & CR-V
01 crv 5 speed project for 2013(((boosted))))
Old Jan 12, 2013 | 09:12 PM
11SECEG's Avatar
Default ---Crv boosted project continued!!!! ----
I have been driving integras. civics and crxs though out my younger years and finally got tired of driving lowered cars.... When my 00 integra 4 door (daily car) got stolen, I knew its time to get something different , something that doesn't stand out that much . .. ; p
01 crv lx
5speed
leather seats
addco sway bars
hr lowering spings
pioneer avicz2
These are the parts the will be put on this month...
inlinepro ac manifold
gt3071r turbo
400hp intercooler
id1000s
competition clutch stage4
act 9 lb flywheel
si cluster
koni yellows
Motor:
stock gsr head
skunk intake manifold
b20 block (stock sleeves)
cp 9.7 cr
eagle rods
acl race bearings
type r oil pump
350-380 hp goal on pump gas.....(enough power to **** off stock evos and sti)
2013 proj.... 01 boosted 5 sp crv proj
2010-2012 proj..... integra is almost done!!!!!!
Old Jan 13, 2013 | 03:53 AM
shermanyang's Avatar
Default Re: 01 crv 5 speed project for 2013(((boosted))))
You won't need to change out the oil pump, all ODB2 oil pumps are the same. You're gonna want to change out the water pump to a vtec one.
Old Jan 13, 2013 | 06:20 AM
11SECEG's Avatar
I am using vtec waterpump & timing belt... I always buy new oil pump on any motors I build for myself or for other people...
Old Jan 13, 2013 | 09:57 AM
sliverSE.V's Avatar
NICE V!
Originally Posted by 11SECEG
hr lowering spings
koni yellows
how much was the set-up may I ask and from where? how low are you and how does it ride? I like Koni (at least for my CRX) I don't want to go LOW I just want to close a little gap once I get a set of rims...thinking te37 replicas or enkie rpf1 in 16s or 17s not sure yet dont want heavy rims and bad mileage..BUT DO post more pictures of the V with those rims please! I'm trying to decided on rims would help to actually know how it looks and since you got a set better visual LOL lmk
BTW also what size is that? rim&tires thanks!
Old Jan 13, 2013 | 06:03 PM
eg92b16's Avatar
Niceeee good luck am doing the same am boost my 99 crv 5 speed !!!
Old Jan 13, 2013 | 06:06 PM
11SECEG's Avatar
Thanks man!!
Rims are 17x8 and tires are 225-50-17
I dont have the koni shocks yet but I was quoted 420 for all 4 ... My friend gets discount on them.... I like my h&r springs ... They ride smooth....
Old Jan 13, 2013 | 06:23 PM
11SECEG's Avatar
Thanks bro
Old Jan 13, 2013 | 07:00 PM
london ritzler's Avatar
This should turn out to be a sweet build!, you'll also be a decent sleeper haha.
Old Jan 13, 2013 | 07:55 PM
11SECEG's Avatar
yes sir!
Old Jan 13, 2013 | 09:21 PM
11SECEG's Avatar
update....more parts....
Old Jan 14, 2013 | 03:32 AM
vinyvolingy's Avatar
going to be an awesome build!
Old Jan 14, 2013 | 08:51 PM
11SECEG's Avatar
more stuff came in today.......
I got the head back from the machineshop for resurface and full valve job...
Block was lightly honed and decked .....I cant wait to start assembling the motor!!
Old Jan 14, 2013 | 11:09 PM
poorsupra's Avatar
this thing is bad ***!! keep up the good work! always fan of a true sleeper!
Old Jan 15, 2013 | 09:40 AM
11SECEG's Avatar
Thanks .... True sleeper! Lol
Old Jan 15, 2013 | 10:47 AM
eg92b16's Avatar
nice build man keep us update with the info !!! just wondering are you going to do any upgrade to the differential ?!?
Old Jan 15, 2013 | 11:57 AM
11SECEG's Avatar
No differential upgrade .... I should be ok since my hp goal is only 350-380 whp...
Old Jan 15, 2013 | 01:48 PM
11SECEG's Avatar
Anyone know who makes bigger sway bars for crv... I have addco sway bars now.... Anyone running whiteline?
Old Jan 15, 2013 | 03:05 PM
qwrty's Avatar
similar diameter...
i was tinkering on a spare s2k sway bar, i just have to fab the mounts and endlinks...
Old Jan 15, 2013 | 08:00 PM
sliverSE.V's Avatar
ordered myself an ADDCO sway bar to upgraded the little oem one but canceled it due to hearing that some peeps have fitment issues and the bushing so I didn't want to deal with that...thinking about ordering me the "ultra racing"? one though it's only 16mm and not 19mm like the ADDCO one...or if I can find something else, haven't heard the whiteline I'll check it out too =P....
BTW you got 17x8 rims I'm thinking of getting some 17x8 any rubbing issues or anything? what's the offset on yours? The set I'm look for is posted on my thread but I'm thinking to go for a set of 17x8 with +38 and hub size 73 you know if I'll have any problems/troubles with that size/offset?? I'll be stock height maybe just a lower spring for closing of gap slightly IF any...not going low or auto-x or anything here just regular DD wanting some nice shoes for the V
Old Jan 15, 2013 | 09:00 PM
11SECEG's Avatar
Yes mine are 17x8 and no rubbing issues at all.... Offset is 38..... I might switch to 18s with 50 series tires... Maybe enkie rpf1...
Old Jan 15, 2013 | 09:22 PM
sliverSE.V's Avatar
enkie rpf1 isn't that what you have? I was thinking the rpf1 too but like more the volk te37 look but volk will break the bank account so gotta go with Rota or something else cheaper besided just my DD =P
Old Jan 16, 2013 | 10:51 AM
11SECEG's Avatar
No mine are not enkie rpf1s.. I wish .. These are motegi rims I got from a friend of mine... I have all 5 rims... I think 18s will look better ....
Old Jan 16, 2013 | 10:52 AM
11SECEG's Avatar
Originally Posted by qwrty
similar diameter...
thanks lmk how the s2k sway bars work out....salamat!
Old Jan 16, 2013 | 11:52 AM
I have 18x8 38 offset w/ 225/45/18 and they don't rub but I'm not dropped...yet. Also with the Addco sway bar, if you run into fitment issues all you have to do is get RSX bushings from an Acura dealer or you can get OEM bushings and use a dremo and grind out some of the innards and reuse the old brackets. That's what I had to do to mine and my buddy's CRVs. Oh...and the size of the wheel hub shouldn't matter if it's too big, if it's too small then it becomes a problem.
Old Jan 17, 2013 | 08:44 AM
11SECEG's Avatar
nice , yeah i had to grind my old busings and reuse the original bracket.. The addco bracket is straight up POS.. Holes didnt even line up.. I want bigger sway bars though... atleast 24mm. I hope the koni shocks help out lessen or eliminate the body roll...
