b16a leaking oil from head on passenger side. new headgasket, still does it.
whats up HT i replaced my head gasket i few days ago, my previous gasket didnt blow, so my oil was never a different color, no water in it, the car ran fine, and it didnt smoke. i replaced the gasket because it had a real small leak coming from the head, right under the vtec solenoid. the oil would seep out and just sit on the block and run down the tranny. when i removed the head studs they were pretty lose and supposedly the motor was oem rebuilt. i put a new felpro gasket on and reused the head studs they are arp's i did not get the head machined either. i just put the new gasket on re torqued the studs and started it put coolant in it and let it run for a minute. i walked over and looked at the motor and it was leaking from the same spot. pretty bad, maybe eve worse then before.. i guess my question is, is does anyone think the head is warped? or possibly the block?? or could it just be these studs are to stretched out to be reused. this is my DD and im afraid if i drive it now with this leak it'll just warp the head or blow this gasket. please help!!!
leak was more than likely FROM the solenoid, and no need to replace the headgasket at all. Not to mention a Felpro, instead of OEM.
Time to break out the pictures.
heres a video of it
and 2 pictures
http://i1249.photobucket.com/albums/...ps2ec2bfbb.jpg
http://i1249.photobucket.com/albums/...ps48b40bce.jpg
and 2 pictures
Did you hand tighten the studs again before you re-installed the head? Did you install the head gasket upside down? 9 times out of ten for a head gasket to be puking profusely like this, its either not torqued enough, which means your studs werent tightener fastened to the block when you tightened the head down. I had 6 head studs come loose when removing my head both times off my block, every time you have to retighten the studs to ensure they are properly hand torqued. The gasket also has an indicator on it that says UP on one side of the gasket, this is true of all aftermarket head gaskets.
no, torquing it more then the head studs are recommended to have on them wont help the gasket sealing issue, something else is wrong. Generally when you do a head gasket your supposed to at least have the head checked for flatness as its the most common thing to warp. Were the two surfaces clean when you reinstalled the gasket?
i reused arp head studs. is it a possibility that my head is warped on that one side? like i said before the gasket before didnt blow, it was leaking on this same side, i figured a new gasket would fix the leak
It's possible its warped, but something definitely when severely wrong during the gasket change. Did you spray anything on the gasket? What did you use to clean the surfaces? You didnt use any sand paper or anything did you?
no, no spray and i only used a clean rag to wipe it down
Im not sure where to point the finger in this instance, but I can tell you the fact that its a felpro gasket isnt the cause. Ive used felpro and victor reinz in my motors for 10 years now, never had a problem as long as the sealing surfaces were ok.
im depressed man ive put so much time and money into this car and now its just coming to a halt, i have no money to put into it and everyone ive talked to seems to think the block is warped. idk i put it up for sale and a guy offered me 2600. its sad but i cant do anything with it now, no car= no transportation, no transportation= no job, no job=no money and we all no what happens to people with no money. lol thanks for the help man i really appreciate it.
lsturbo*
May 6, 2008 07:18 PM
lsturbo*
Apr 30, 2008 04:41 AM
