Overheating. Does this sound like waterpump?
Old Jan 11, 2013 | 05:21 PM
themiz816's Avatar
Default Overheating. Does this sound like waterpump?
Car: 1998 Honda Civic 4 cyl vtec 2.3L
i was driving around after i replaced my iacv and the temp went way up. i had lost some coolant from spilling out of the iacv so at first i just thought i was low on coolant. but then i let it cool down and it still overheated. at one point while i had the engine open waiting for the car to warm up i remember noticing that one half on the radiator hose was hot and the other half was cold. IS THIS UNUSUAL? Is this enough to make you think there is poor coolant circulation and need to do the water pump? Also just before the first overheating, i remember backing the car out of the drive way and thinking i was hearing a strange fluid sound. I pulled into the drive way and verified no leaks. So I went on and then proceeded to overheat.
Old Jan 11, 2013 | 05:46 PM
jdowen2's Avatar
Default Re: Overheating. Does this sound like waterpump?
I would think thermostat first.
Old Jan 11, 2013 | 05:49 PM
Fliptard's Avatar
and make sure the coolant system is properly bled.
Old Jan 11, 2013 | 05:53 PM
92 civic ex 4dr's Avatar
I would replace the thermostat and go from there. Ten bucks might fix your problem
Posted from Honda-tech.com App for Android
Old Jan 11, 2013 | 05:57 PM
themiz816's Avatar
I was gonna ask about that. I lost a lot of fluid when I ran the car and didn't have the iacv on right. you think air in the system could cause it to overheat?
Old Jan 11, 2013 | 05:58 PM
Fliptard's Avatar
yup
Old Jan 12, 2013 | 08:57 AM
themiz816's Avatar
sure enough I just needed to bleed the system
Joshable14
Jul 20, 2015 10:10 AM
4doorpowa
Jan 24, 2011 12:50 PM
jadugartir
Aug 4, 2005 12:15 PM
Cashis Lee
Apr 28, 2005 04:29 PM
