p1381 code accord 96 ex f22b1 video and picture inside please help
hi, please I need some help...
I have accord 96 ex with f22b1 engine...
I been fighting with p1381 code...
only with 60k miles.
the problem is the car won`t start at first try
I erase the code and start the car and It do again p1381 code...
I check the resistance in the cyp sensor inside the distributor and the resistance are in good range... between 700-1300 ohm
I read other treat and really I don`t find something to help me...
they said to replace the distributor but I want to be sure before paid for something... and some of the post replace the distributor and don`t resolved the problem...
I put the multimeter and read the resistance when I try to start the car and I think there is some point it cut...
I open to any suggestion...
please look the video and help me out:
Last edited by charliccs; Jan 11, 2013 at 08:23 AM. Reason: won`t charge the video
yesterday I try another distributor and didn`t fix the problem, the same code after I reset the ecu with the scanner...
I try changing the sensor inside and the same problem...
what is the next step to check? any help?
I thinking in testing the crankshaft sensor... I have the 4 pin connector next to the timing belt...
what is the procedure to test the crankshaft sensor?
A simple google search with that code will tell you what causes it. Here you go:
-Corroded electrical terminals leading to the distributer
-Defective or weak Ignition coil
-missing or incorrectly installed ignition coil shield
-alternator diodes or regulator failing causing irregular line noise
-damaged sensor wire (usually yellow with a purple jacket where shielding begins.
-Defective ECM or PCM
-Faulty Cylinder Position Sensor.
My guess is the ignition coil, who knows though.
problem fixed... thank`s god...
I bought a used ecu 38720-poh-l51 in ebay and westerday installed in the car and no more check engine light and the car start the first try...
thank`s for the help...
deercanbrack
Apr 29, 2008 11:13 AM
