is a d15b worth it or go d16y8
There are many flavors of the D15B. Maybe spec them out and then YOU can answer your own question because, frankly, no one has a clue what is "worth it" to you. And this isn't really a tech question.
the best swap would be a z6 with the better oiling at the crank. sometimes it takes some modification for it to work or drop right in.. the d15b is over rated and if this is just a DD you dont plan on boosting or doing anything but bolt on's the y8 would be fine.
Rhythm Racer
10
Oct 1, 2003 08:35 PM
