LED constantly flashing.. Clifford Matrix 330.3X
Old Jan 11, 2013 | 12:17 AM
TiMMDoGG's Avatar
Default LED constantly flashing.. Clifford Matrix 330.3X
So I wired up my alarm and everything works perfect. But I noticed that my LED on the center command is constantly blinking not only when it's armed as it should be but is also blinking unarmed even when I'm driving. It's right in my face so it's hard to drive with a bright blue light constantly flashing. Lol. I've done alot of reading and it has all the symptoms of being in vallet mode, I did some reading in my manual on how to enter and exit vallet mode and nothing is working for me. It's still constantly blinking.. Anyone have any other tricks or thoughts as to how to fix it? Help! Please and Thank You!
Old Jan 11, 2013 | 03:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: LED constantly flashing.. Clifford Matrix 330.3X
It will stay on constant if the alarm is in valet mode. Check your wiring/connections.
Old Jan 11, 2013 | 09:15 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You need to wire up the yellow wire on the h1 harness to true ignition. The alarm does know the car is on to reset. Simple test..... can you arm the car while it is running? If so the ignition wire is not hooked up correctly.
Old Jan 11, 2013 | 04:33 PM
uberEFtuner's Avatar
X2
If you set off the alarm during testing, it will blink constantly. This is to tell you that someone has set off the alarm while you were gone. BUT if the accessory wire is not hooked up it never knows that the car has been started. I left mine unhooked because I did not want it to power up the radio when I remote started it. But I did finally just hook it up.
GsDAteg
Audio / Security / Video
Mar 18, 2010 04:40 AM
Jdmglenn
Oct 20, 2006 05:38 PM
flatblack-h22
Jul 12, 2006 10:30 PM
technine
Dec 17, 2002 08:54 AM
