** Not Your Average Honda Dealer **
Clockwise Motion Baffle for K20A -K20A2 oil pump/pan setup
$275 shipped instock!! :up:
Pay now with Paypal!! please make sure your screen name is in the message box, click and done!
Works with type-s pump/type-s oil pan
Honda K20A "Easy Fit" baffled sump kit designed to fit inside the factory sump pan without any modifications.
This baffled sump kit is located across the original sump pan inner webs and is sized precisely so that the factory windage tray locks it in place when you refit the sump.
Avoids the need to drill holes at impossible angles or TIG weld to oil saturated aluminium.
A must if you are running a wet sumped K20 in anger unless you have access to a plentiful supply of big ends bearings!
Very High quality piece!
Paypal is hondaparts@autofair.com
**please add your order and screen name in the comment box thanks
Remflex Exhaust manifold gaskets Made in the U.S.A.
These Ultra high temp Exhaust manifold gaskets are incredible!
We have seen some Turbo guys melt their gaskets!. This is the solution. :up:
$35.99 shipped
• Seals Warped Flanges:
Remflex exhaust gaskets come in a standard 1/8-inch thickness and are designed to crush 50%. This allows them to fill gaps in the flange surface up to 1/16-inch! Remflex Performance Promise
• Won’t Burn Out:
100% flexible graphite construction means Remflex gaskets are good for up to 3,000 degrees F—far exceeding that of any vehicle’s exhaust system temperature!
• No Re-Torquing Necessary:
Remflex exhaust gaskets rebound 30%, creating an optimum seal that eliminates the need to re-torque!
Remflex gaskets work because they solve the two main problems associated with sealing an exhaust flange: Warping, and gasket failure. These are onetime use only.
K-series instock @ Autofair honda Add one in with your oem parts order!
$35.99 shipped
paypal is hondaparts@autofair.com
*** Bseries Also In Stock****
We have the Karcepts line here at Autofair, mix and match when buying your oem K-series parts. Pick up your RSX shift box with your Karcepts shifter plate and get your RBC/RRC with your throttle body adapter. :wink: dont see what your looking for? just ask!
KARCEPTS
We now have MTEC shifter springs for K-series manual transmissions.
These will fit K20 or K24 manual trans. They help eliminate lateral play that exist in the shifter. Basically it helps with your side to side movement on your shifter. Giving you a more accurate gear engagement!
Race version $35 shipped including paypal fees
Click and buy now with Paypal!
These are in stock and ready to ship
Here at Autofair Honda :up: Instock
Denso Iridium Spark plugs
-- IK22 great for boosted applications
-- IK24 great N/A spark plugs
$44.99 shipped for a set of 4
**please add your screen name and order in the comment box, thanks
You can also add to your oem parts order.
BNIB RSX-S Denso primary wideband A/F sensors
Just arrived!!
We have these instock ready to ship. This is exactly what you for your Kswap or RSX-S replacement. No more screwing around with malfunctioning sensors or overpaying for one.
Only $119.99 shipped to your door
**please put your screen name and order in the comment box
We now have the Dgauge from Brockway Engineering here at Autofair
$399 MSRP
These are unmatched quality, definatly amazing !! Free shipping from AFH !!!!
Pm me for special pricing, you can also add this to your oem parts order
The DGauge is a digital multi-gauge that plugs into the diagnostic port on most 1996 and later Asian, European and some US vehicles and displays real-time engine data on it's color TFT LCD. Through the selection of one of 3 different screen modes, you can monitor 2 or 4 user selectable parameters at a time. As many as 25 different parameters are available for viewing, depending on vehicle support and 7 parameters via external sensors. Exceptionally easy to set up and operate. With unmatched performance and reliability, the DGauge offers the most advanced technology in engine monitoring.
100% compatible with all K-Series applications utilizing the factory ECU.
100% compatible with K-Pro. Monitor A/F ratio, engine temp, boost and more.
http://www.brockwayengineering.com/
**Instock always at Autofair Honda
Great to add to your RBC or RRC manifold order:up: Lower your intake air temps and are reusable!!
pm me or email at jadams@autofair.com
Powerrevracing thermal intake gaskets & throttle body gaskets
Just some examples of the K-series gaskets we have here
**any gasket is availible, pm me for your specific application
Intake manifold gaskets $34.99
-K24A2
-K20Z3
-K20Z1
-K20A3
-K20A2
-K24A1
-K24A4 etc..
Throttle body gaskets $22.99
-K20A2
-K20A2 70mm
-K20Z3
-K20Z3 70mm
-K20Z3 72mm
-J35
-09 TL-SH
-also the 09 TL-SH AWD bigbore throttle body adapters for the RBC/RRC manifold
us on FACEBOOKP2R S2000 clutch master cylinder spacer
-P765
This spacer allows you to put a S2000 Clutch Master Cylinder in a 92-00 Honda Civic or 94-01 Integra and some others. No need to modify the clutch master cylinder, just bolt it on and done! Made in the USA
$29.95 shipped for the spacer
-- or --
$122.95 shipped for a P2R spacer and new OEM S2K cmc
please add your order and screen name in the commet box thanks
-oem cmc gaskets available in addition **
I have a question for you. can you get me the side skirts for a 97 civic hx coupe. If you can get me the price for the regular black ones and also the ones that come painted milano red. Just pm me thank you.
