Suspension & Brakes Theory, alignment, spring rates....
Skunk2 pro s2 vs megan ez street cloilovers?????
Old Jan 10, 2013 | 10:01 AM
jamhnda2292's Avatar
Icon2 Skunk2 pro s2 vs megan ez street cloilovers?????
This is my first time getting full coilover set for ej2 and i wanted to get opinions on these two thanks
Megan ez street coilovers and
Skunk2 pros2 coilovers
Old Jan 10, 2013 | 10:09 AM
datbumper's Avatar
Default Re: Skunk2 pro s2 vs megan ez street cloilovers?????
Do more research. There are much better options out there, especially for the money. Take the Koni/GC setup for example; $825 and a lifetime warranty.
Old Jan 10, 2013 | 12:06 PM
Aite thanks so what do you think about the koni yellows with eibach springs see becuase the thing is i have the coilover sleeves and im bouncing everywhere
Old Jan 10, 2013 | 12:37 PM
GagnarTheUnruly's Avatar
Oversprung, underdamped. A reputable coilover like the one datbumper mentioned will be neither.
Old Jan 10, 2013 | 01:15 PM
so what would your set up be
Old Jan 10, 2013 | 01:34 PM
what would be a good set up to you
Old Jan 10, 2013 | 02:12 PM
grumblemarc's Avatar
The Grumpiest
Please do some reading. Eibach makes the springs for the Ground Control sleeves. And you CANNOT use regular lowering spring on an adjust sleeve.
Old Jan 10, 2013 | 06:39 PM
There is a sticky at the top of the form that has lots of info on brands.
Old Jan 11, 2013 | 03:38 AM
Libertariat's Avatar
Ek Forever y0!
Please read the sticky at the top of the forum.
fyi, you're bouncing because your dampers aren't properly suited for your spring rate/ride height.
Old Jan 11, 2013 | 03:32 PM
ya thanks i saw the thread aafter posting this my bad
Old Jan 11, 2013 | 03:34 PM
ya my bad i saw the thread after posting this and its becuse im riding on function form coilover sleeves on regular struts
Old Jan 12, 2013 | 08:10 AM
98civdx's Avatar
Master Detailer
Do you want crap, or ****? Your choice.
Old Jan 12, 2013 | 08:23 AM
haha thanks and would you go with progress cs 2
Old Jan 12, 2013 | 08:30 AM
98civdx's Avatar
Master Detailer
How low do you want to go?
Old Jan 12, 2013 | 08:32 AM
not slammed but not regular height
Old Jan 12, 2013 | 08:34 AM
xTyFighterx's Avatar
CHOP THE STOCK SPRINGS! ITS FREE! AND DANGEROUS!
Old Jan 12, 2013 | 09:36 AM
The Grumpiest
Let's be even more vague shall we? Name a number.
Old Jan 12, 2013 | 12:13 PM
datbumper's Avatar
Just go with a reputable one. Never, ever cheap out on parts. Better to buy quality than quantity. That's definitely one lesson I've learned in life. Progress CSII's or Koni/GC is your best bet (Koni/GC ftw!). If it's a DD, a good, median rate is 350f/350r.
Old Jan 12, 2013 | 05:30 PM
Aite thanks
Old Jan 12, 2013 | 05:41 PM
idk a number becuase im still a new to this but the same hieght the hatch on the thread on top
Old Jan 12, 2013 | 06:59 PM
For reasons I don't want to get into, Progress coilovers should primarily be thought of as non-adjustable, because the actual useable range (at typical rates) is very low. If you want a lot of adjustability go with Koni/GC or the like. But if you are happy with a ~1.5" drop Progress coilovers are very good.
This is the ride height you'll get from Progress, +/- 0.5" or so.
Old Jan 12, 2013 | 07:11 PM
98civdx's Avatar
Master Detailer
This hatch?
Old Jan 12, 2013 | 07:38 PM
This hatch?
Ya that one
Old Jan 12, 2013 | 07:42 PM
Thanks
Old Jan 12, 2013 | 07:58 PM
98civdx's Avatar
Master Detailer
Hatch is a 2-2.5'' drop, IIRC.
