My stock '93 D16 surges when hot.
Old Jan 10, 2013 | 09:12 AM
Fix-it77's Avatar
Default My stock '93 D16 surges when hot.
hey everyone- new to this forum. I have a stock '93 Del Sol with a D16Z6 SOHC V-tec. It sat for 5 years after I git my daughter a different ride. Starts / runs / drives fine, no electrical problems evident ( everything works as it should).
When it gets fully up to temp, it still runs fine, tachs up to 6K+ no problem, pulls strong- no stumble or power loss. Sometimes when you come to a stop, and go to take- off it stumbles / cuts out / wont rev. Sometimes cycling key off/on will prime system and let me get through intersection.
Sometimes when driving steady state it surges , 2-4 sec of full power, 2-3 secs of power loss/ rpm drop. It will do this until I can slowly milk it up to say + 40 mph / 4K rpm it will start running fine and then do itagain after next stop.
I have replaced the fuel pump, main relay, filter, purged lines before and after filter. Also removed FPR and Fuel Return Vacum operated solenoid, cleaned and flushed them and the fuel rail. when cold it maintains pressure in fuel rail for several minutes, haven't checked it hot.
What signals the pump to shut off after the 5 sec prime on start up? Can the pump be shutting off / cycling due to an intermittant signal from ECU or a pressure switch I don't know about?
Help!!! gotta have it reliable so my son can use it for college daily drive.
Old Jan 10, 2013 | 09:45 AM
Former User's Avatar
Default Re: My stock '93 D16 surges when hot.
Consider doing and full ignition system tune up - replace plugs, wires, cap, and rotor and adjust the ignition timing.
Old Jan 10, 2013 | 10:38 AM
Fix-it77's Avatar
New wires/cap/rotor 5k miles ago.pulled plugs / all nice tan even burning.
hondacivic90zc
Dec 20, 2012 09:09 PM
vteck1ck
Feb 13, 2010 10:12 AM
axionm1k
Jun 4, 2008 06:41 AM
JDM_SOHC
12
Oct 10, 2005 04:19 AM
Hybridcrx469
Nov 10, 2004 01:17 PM
