stock 93 ej1 shuts off well driving
My 93 coupe shuts off wen im driving, I changed my injectors,dizzy ,and ecu. If i turn key to off position then back to on position and pop start it then the car starts but if i dont do that and just try to pop start it den it dont work. So what can it be? IOOts not throwing any CEL's, need help trouble shooting.
Re: stock 93 ej1 shuts off well driving
It sounds like the car only starts when you prime the fuel system (turning key to on) a couple times. Change the fuel filter if you haven't in awhile and if that doesn't help, check your fuel pressure.
It could be your main relay, but I doubt it would be working then not. I would go with delsolproblems, check/replace your fuel filter. There only 12.99$ at O'reillys
What do you mean you checked it and it flowed good? You can try swapping the main relay like I said it might be. Other than that check all your grounds. Make sure they are tight, and not just on there.
Borrow a fuel pressure tester from a parts store to see if the pump is working properly. Make sure the air filter is not the culprit as well.
I changed my iacv and let the car run for about a hour then shut?the car off then back on and it is fine, so the real test will be when i drive the car!
Shane Henry
03-05-2014 05:14 AM
