CRX SI B18A1 Code 8
Old Jan 9, 2013 | 09:39 PM
CrxGrin's Avatar
Default CRX SI B18A1 Code 8
Hooked up my 4 wire o2 to my jumper, i triple checked it's hooked up correctly. But immediately after I hooked it up I am throwing a code 8 now.... Seems to random to just happen at the same time. Any ideas?
Old Jan 10, 2013 | 05:00 AM
Former User's Avatar
Default Re: CRX SI B18A1 Code 8
Reset the ECU to see whether the code returns. If so, resistance test the TDC sensor. Check the two wires for a short or open.
Old Jan 10, 2013 | 07:43 AM
CrxGrin's Avatar
Pulled the ecu and waiting now, but while I waited for it to warm up I noticed it was idling really low at maybe 400 rpm.
Old Jan 10, 2013 | 09:34 AM
It's normal.
Old Jan 10, 2013 | 09:47 AM
CrxGrin's Avatar
Well my tester screen is busted.... But I have to go to work, will it be ok to drive for a bit with the tdc sensor possibly bad?
Old Jan 10, 2013 | 10:16 AM
CrxGrin's Avatar
I found another multimeter, it tested at 411 which is fine to my understanding. So that means my distributor is fine correct?
Old Jan 10, 2013 | 10:17 AM
Did code 8 return after resetting the ECU?
Old Jan 10, 2013 | 10:26 AM
CrxGrin's Avatar
Yea it is still there.
Old Jan 10, 2013 | 10:27 AM
Originally Posted by RonJ@HT
Check the two [TDC sensor] wires for a short or open.
Do these^ two tests from the two TDC sensor wire pins in the ECU connector.
Old Jan 10, 2013 | 10:31 AM
CrxGrin's Avatar
So trace them back to the ecu through the loom you mean?
Old Jan 10, 2013 | 10:34 AM
You test the wires with a multimeter. Do you have an OBD1 or OBD0 ECU?
Old Jan 10, 2013 | 10:43 AM
CrxGrin's Avatar
Obd1
Old Jan 10, 2013 | 10:48 AM
From unplugged ECU connector B:
1) Measure resistance between B13 and B14. It should be about the same as you measured for the TDC sensor from the distributor plug.
2) Individually test for continuity to body ground at B13 and B14. There should be none.
http://www.phearable.net/tech/wiring...schematics.gif
Old Jan 10, 2013 | 11:48 AM
CrxGrin's Avatar
If I did it correctly, resistance between b13/b14 is roughly the same as the dist test. But the ground test "if I did it right" came out with a reading of 1.7 for both.
Old Jan 10, 2013 | 12:16 PM
CrxGrin's Avatar
Also I unplugged my jumper for the 4 wire o2 just now. Car runs fine... Still starts a bit hard but it accelerates fine and feels normal now.
Old Jan 10, 2013 | 12:27 PM
This^ is the problem and the cause of code 8 - an electrical short(s). Now unplug the distributor connector and repeat the same short tests to see whether continuity to body ground is retained or eliminated at B13 and B14.
Old Jan 10, 2013 | 12:31 PM
CrxGrin's Avatar
ok doing that now
Old Jan 10, 2013 | 12:33 PM
Did it run poorly before? Did code 8 disappear? If so, maybe you mistakenly spliced into the TDC sensor wires?
Old Jan 10, 2013 | 12:44 PM
CrxGrin's Avatar
Distributor connected: Wht/Blu=1.7 Orn/Blue=1.7
Distributor Disconnected: Wht/Blu=O Orn/Blue=1.7
Old Jan 10, 2013 | 12:46 PM
This^ result tells you that each wire has a short somewhere between the ECU and distributor plugs. Might be easiest to just run two new wires of similar gauge.
Old Jan 10, 2013 | 12:47 PM
CrxGrin's Avatar
Code 8 stayed after unplugging the o2 jumper. Also It was a straight foward seperate harness for the o2 from Zerg. Kind of stupid proof I would think.
Old Jan 10, 2013 | 12:49 PM
CrxGrin's Avatar
Good deal I'll depin the ecu harness and run 2 new straight cables. Thanks for all your help saved me a huge headache!
Old Jan 10, 2013 | 12:52 PM
Old Jan 10, 2013 | 01:09 PM
CrxGrin's Avatar
Well that sucks, straight wired it and im still getting code 8 and 1.7 reading. Good cable straight from the distributor to the Ecu.
