D16Z6 wont crank after aligning timing
Old Jan 9, 2013 | 01:00 PM
blue_egsi's Avatar
Default D16Z6 wont crank after aligning timing
hey guys.i have a eg6 with a d16z6 motor.the first problem i had with my motor was a motor mount screw was broken n i had to replace it.so i pulled out my whole engine and took out the timing cover and replace the timing belt.little did i know during this process i was messing with the timing for the camshaft and crankshaft n threw it all off.i did my best to align it n installed everything back on and put it back in my car after replacing the broken screw.when i tried to start the engine after the this issue the motor didnt want to start but u can hear it cranking over like every other motor that doesnt want to start...so i looked up in the net n found out it mite of been my align for my crankshaft and camshaft cuz i wasnt too sure if it was align right/perfect during the process of the broken motor mount screw.so i did some research and attempt to realign it last nite and i did my best at it like how it was shown to me on certain websites with all the indicator;such as the cam gear up has to be up,cam gear at 3 and 9 o'clock with 7 o'clock,crankshaft white paint align with the arrow and such .after realigning it now my engine wont even gauge at all to even hear it having a problem to start at all.all u hear is the starting jst kicking in.no crankshaft noise trying to work or such jst the starter.anyone know what cud b the problem?
Old Jan 9, 2013 | 01:25 PM
Former User's Avatar
Default Re: engine wont gauge after aligning timing
Is the battery dead?
Here are some other items that may help:
If the mechanical timing^ is now fine, then check that the spark plug wires are connected in the correct firing order on the distributor cap. If fine, compression test the cylinders.
Old Jan 9, 2013 | 05:32 PM
blue_egsi's Avatar
tyvm but what if the only thing i hear is only the starter cranking only?
Old Jan 9, 2013 | 05:35 PM
Does the starter turn the engine? Or does the starter motor only turn?
y@ki$oB@.
May 2, 2009 10:47 AM
RedRevolver
Mar 24, 2009 04:18 AM
rasta420
Nov 1, 2004 05:29 PM
EGcivicBoy
Nov 12, 2003 11:08 AM
