Top Hat Q?
I am about to purchase my Koni & GC set up and want to know if I should get the rear top hats as well? I own an EK sedan and will be lowering it about 2". I'm definitely going to get the fronts but am not sure if I need the back.
It will not reduce camber.
They do. Do the washer trick in the rear if it becomes an issue.
I lost about 1* in the rear by doing the washer trick. I used 2 washers on each bolt, but it depends on the size of the washer you use.
Most of our clients who purchase our extended top hats purchase them for the front. But we have had a number of clients who have purchased them for all 4 corners, so it is not unheard of to run the extended hats on all 4.
STN_Pat
Jun 1, 2015 01:44 PM
WalkingKenshin
Mar 10, 2004 03:36 PM
StinkyTofu
Sep 19, 2003 07:06 AM
