Suspension & Brakes Theory, alignment, spring rates....
my ride height is off by 4mm??
Old Jan 9, 2013 | 12:17 PM
theguy22's Avatar
Default my ride height is off by 4mm??
I have function and form type 1s on my 1997 civic coupe. the front measured to be the same (1mm 0ff) but the rear of my civic measured differently. it's about 4mm higher on the rear left than the rear right. i measured the car from the center of the wheel to the fender. and i was wondering if anybody thinks my ride height is off? does it sink from the front more or the back? i notice when i put my finger in the BACK tire, it feels like its a bit lower than the front. but when i look at it, the front looks lower than the back. but i do notice that the fenders in the rear has like this flab on it. i appreciate your input.
Old Jan 9, 2013 | 12:29 PM
mechanix619's Avatar
Default Re: my ride height is off by 4mm??
Its looks fine front to back. As long as the sides are level with each other; front left and right, rear left and right.
The best way to balance everything out is to find a shop that can do corner weight.
Old Jan 9, 2013 | 01:06 PM
theguy22's Avatar
does being 4mm off matter much? jw
Old Jan 9, 2013 | 04:43 PM
grumblemarc's Avatar
The Grumpiest
Are we being serious or are we trolling. 4mm? C'mon. They are ADJUSTABLE! Adjust them.
Old Jan 9, 2013 | 05:03 PM
theguy22's Avatar
No I'm serious I always need my stuff to be perfect. Well is that a lot to worry about? 4mm? And for some reason when I try seeing how far apart the tire is from the fender with my finger. There is more of a gap at the front than the rear. But obviously the front looks lower. Is that just because the rear has that flap?
Old Jan 9, 2013 | 06:07 PM
98civdx's Avatar
Master Detailer
4mm? lol
If you want the height dead even all around, break out a measuring tape and start adjusting the coilovers.
Old Jan 9, 2013 | 08:23 PM
theguy22's Avatar
Originally Posted by 98civdx
4mm? lol
yeah, its a difference in which i had to measure and after measuring i can kinda feel it. but im really picky i guess. ill leave it like that.
Old Jan 10, 2013 | 12:45 AM
Kozy.'s Avatar
a.k.a. Komodo
You don't appear to be sitting in it, thus, it doesn't bloody matter.
Old Jan 10, 2013 | 03:20 AM
EM1 Jowee's Avatar
i usually measure the car at the jacking points on a level ground, and if the the car is adjusted evenly, the front should have more of a fender gap than the rear. its probably designed like that for turning clearances
Old Jan 10, 2013 | 06:34 AM
Just measure from the top of fender to the ground. The front should be a tad lower than the rear.
If you want it perfect find a shop that can do corner weight.
Old Jan 10, 2013 | 07:02 AM
wanabebuff's Avatar
Just adjust it for the 4mm.....its really not hard, if you can measure the 4mm difference yourself, then you can adjust it yourself. Or just take it to a shop and tell them your problem and have the laugh at your when they graciously take your money
Old Jan 10, 2013 | 07:07 AM
Libertariat's Avatar
Ek Forever y0!
My whole driver's side is about 6mm higher so when I sit in the car it's perfect on each corner.
That's how little it matters. Unless you're doing autocross or road racing like I am then you should really not worry about it. I have to worry about alignment being in spec when my 175lb self is in the passenger seat so that my car behaves as it should left to right so that I learn the car properly.
redlinetuning
May 2, 2014 08:40 AM
ke98248
May 25, 2007 07:37 AM
DaChoZn1
Oct 11, 2004 07:26 PM
BoM
Jul 16, 2001 11:05 AM
