Camshafts for h22a1 (question)
Hi there,
i know there are many of this threads, but I want to know if I can use F20B camshafts on h22a1, or if its better to buy h22a cams or BC Stage2 or SK2 S2?
Someone that have already tried and been through this.
Thanks
Thanks
i have used the BC stage 2 n/a cams with succes in my h23vtec. I alos have a set of BC satge 2 turbo cams that are awaiting to be put into a boosted h22.
For the price they are excellant, i have no issues with qulity and i have found that most people who bash BC product havnt used them, but rather are talking about second hand expereinces of others.
Either choice is a good, one, stock cams are great but limited for N/A.
Depends on your goals for the engine, and factors like displacement, compression ratio, and intake/ exhaust size you plan to use.
There are a bunch of threads comparing cams in the all-motor and hybrid sections.
If on Facebook, guys are always posting up cams for sale in the H-series group.
From what I have seen/ read Skunk2 cams for the H22 are great, and they have 6 cams to choose from, depending on engine specs. Personally for my needs in a cam I picked up the Pro1, and couldn't be happier with them.
Thanks, how can I find the H-Series group? Also, I've seen that H22A have more lift the BC Stage 2!? But I guess the BC have to be better!? Am I right? Or just suck$$g
can you post specificatiosn of said cams? lift and duration.
i woudl like to compare them to the specification sheet i have fro the BC ones. Just cuz im curious.
EDIT:
on the BC page is the specifications. below is the link
http://www.briancrower.com/makes/honda/h22h22a.shtml
EDIT:
