basic instrument cluster question
ok, what in the hell is the green wiring thing on the back of the cluster?
or can someone tell me where one can buy one?
94 del sol Si
1.6 SOHC Vtec D16Z6 engine
5speed manual shift
94 del sol Si
5speed manual shift
no, my bad i wrote that in a hurry, i mean like the brain, or motherboard of the cluster, like the thing that provides the power for the gauge lights
some lights work, some dont, the clock flutters on and off without keeping the time, the 'motherboard' is sretch like from the years of waer and heat, so i just want a replacement
and i've done checks on all fuses and leads for the wires so i know none of that is the problem, and the 'broken' lights and been tested with power, so i know thats not the problem
Just get a replacement cluster. However, I still doubt that is the root cause of the problem.
Last edited by deschlong; Jan 9, 2013 at 02:52 PM. Reason: CAN be bought separately!
actually, it can be, i just found a place that sells the whole unit or it in parts, and i know it's my problem, i know what im doing, thanks
Not to be mean, but if you knew what you were doing then you would know it is a plastic circuit "board" And if you are really really good at electronics you can easily create jumper lines to skip over the damaged sections.
you want #10 i believe http://torontohondaparts.com/Honda/D...OMPONENTS/9785
i found it cheaper at another site, but yes, thats it, and thanks
2. for me to bypass broken sections, i might aswell just build me a new board, hence me wanting tto buy a new one.
catsman50
15
Aug 1, 2011 11:57 AM
snuggles
Jun 10, 2004 08:47 PM
