Headlight\Electrical Problem
Old Oct 20, 2002 | 10:53 AM
Beach Accord's Avatar
Default Headlight\Electrical Problem
i posted this a couple days ago but i need some clarity. the point at which the connector connects to the bulb. there is two wires a red and black. my headlight kept going out and i looked at the wires and the black one looks to have some of the covering off and the wires are exposed and green. when i wiggle this wire it turns the headlight off and on. what do i need to do to fix this? i am not going to just wrap it with electrical tape cause i wanna actually fix it. how would i repair this. it doesnt look like i can just cut the wire down and re-insert. its too snug 4 that. also i dont see replacing the entire harness since i cant seem to find the end of its. (its all loomed up). any help would be great.
Old Oct 20, 2002 | 11:13 AM
RotaryBzzz's Avatar
Default Re: Headlight\Electrical Problem (Beach Accord)
You could go to Home Depot or something like that and find a copper de-oxidizer solution for faucets. That black wire is the 'ground' wire for the headlight...its completing the circuit back to the chassis+battery (-). Try that stuff, get it clean then wrap tightly with electrical tape.
What you could also do is cut the whole connector off and splice in a connector from another accord from a junkyard or something. Maybe even another car from even another year as long as its the same size. Those connectors are pretty standardized.
Edit: I'm surprised that a 2001 accord is showing this kind of problem. Take it in for warranty work? I think the body had a 100k mile corrosion warranty....?
[Modified by RotaryBzzz, 12:15 PM 10/20/2002]
Old Oct 21, 2002 | 02:43 PM
Default Re: Headlight\Electrical Problem (RotaryBzzz)
thanks for the tips. i had a feeling that this was caused by me runing those crappy blue higher wattage bulbs when i first got my car. then i switched to HID.s and i was having problems with that side with the HIDs....the ballast i thought but i guess my harness was fried. took it to honda today and they had to replace a couple of things. only 45 bucs for the three parts and they wanted another 45 for labor......bwahaha...installed the new plug and connectors myself. seems the whole **** had melted. to me for paying so much for easy to findshit but oh well.
-chris B
Old Oct 23, 2002 | 04:40 AM
ratherbewalking's Avatar
discount auto parts sells a replacemtent. under 5 dollars i think.
Old Oct 23, 2002 | 06:32 PM
jspark79's Avatar
I got a similiar problem with my lighting...I tried to wire my bumber lights to second as foglights by connecting a new line to the turnsignals and disconnecting the bumber lights...it worked for a day and then stopped.....I defaulted the setup and now my turn signals dont work and the bumbers do.....I still can't figure out whats the matter
Old Oct 23, 2002 | 06:56 PM
KTeller8's Avatar
Default Re: Headlight\Electrical Problem (jspark79)
well my one side goes off and on
those crappy blue lights i used to have where too high wattage and burn the little plastic housing.
prelude182
Feb 24, 2011 11:23 AM
91akira
Audio / Security / Video
Mar 13, 2010 06:07 AM
97tegblk
Lighting
Sep 25, 2007 02:19 AM
Racermech
May 23, 2005 08:29 AM
rufiogeezee
12
Feb 18, 2005 01:24 PM
