HUGE k series part out k20z1 sleeved block pauter rods skunk2 stage 2 cams k20a TB IM
been a long time since i been on here but this motor was in my old em1 with k20z1. the piston hit the head and broke one valve so i put a k20a swap inside the car instead and heres the leftover parts of the car.
k20z1 benson sleeved block 1mm over standard bore with pauter rods k20a2 crank cp pistons 11.5cr . will need new set of pistons and bored/hone. $1400shipped or $1250 picked up in dallas tx
block before build
http://xb7.xanga.com/ea0e0b372213427...b222184469.jpg
current block pic
http://x91.xanga.com/46ae1543d423228...b226969041.jpg
http://xa1.xanga.com/3f5e03712103228...b226969042.jpg
http://xac.xanga.com/d00f9577d423028...b226969043.jpg
http://x8f.xanga.com/c33f8a752453328...b226971452.jpg
k20a2 head with ferrea standard size valves,bronze valve guides,valve keepers, with crower springs retainers and skunk2 stage 2 cams ONE retainer broke and the botton needs work and resurface asking with JDM valve cover with spark plug cover $700shipped
http://xeb.xanga.com/ca1f8b74d553328...b226969053.jpg
http://x39.xanga.com/94be117ad553328...b226969054.jpg
parts before install
http://xa7.xanga.com/8b9e063a2533527...b222184470.jpg
http://xf6.xanga.com/19ce0a022533427...b222184471.jpg
http://xd7.xanga.com/c04e30376213427...b222184472.jpg
k20a type r TB and IM with fuel rail IM cover $200shipped
power steering pump $60shipped
http://x34.xanga.com/03ff8b7bd563328...b226969067.jpg
k20a2 ac compressor $60shipped
k20a type r engine harness with fuel rail & injectors, coil packs $170shipped
heres pic of some of the stuff i have for sale from the k20z1:
$60shipped for thermo with pipe
timing cover, chain, guide and tensioner not parting out $120shipped
The rest below are from a 05 TSX
power steering pump $50 shipped
windage tray,oil setup and chain + beat up oil pan $150shipped
k24a2 and k20z1 sepentine tensioner $40shipped each
k20a2 oem header $30shipped
stock clutch and PP added for $20 more
ap1 starter $90 shipped
ap1 engine harness $180shipped
i also have the remaining block parts like water pump and oil pump and chains. im open to offersparts are located in arlington texas. paypal only and with members that arent new with zero posts..not risking to get scammed sorry..email itrboy@yahoo.com for fastest response since i get notified on my phone instead of inbox but you can also inbox. open to combining parts for better price. thanks
block before build
current block pic
