eG WITH B16a transmission wont engage???
Old Jan 7, 2013 | 06:05 PM
Hatcheys314's Avatar
Icon6 eG WITH B16a transmission wont engage???
I have a 95 civic hatchback with a b16a swap? For some reason my transmisson isnt engaging when i release the clutch... I still have the same pressure on my clutch as before this happened.... When its in gear and i release the clutch and give it gas the speedometer still moves as if i was driving... i thought it was the pressure plate but now not so sure.... any info would be greatly appreciated?!?!?!?!!?!!?!
Old Jan 7, 2013 | 06:22 PM
jbpnoman's Avatar
Default Re: eG WITH B16a transmission wont engage???
If the clutch pedal feels the same, and your speedometer is still acting like your car is driving normally, it's either an axle problem or a transmission problem. Check your axles.
Old Jan 7, 2013 | 06:26 PM
i just replaced the axle that was messed up..... it goes in and out of every gear fine doesn't grind or make noises.... could it jus be the diffferential or the pressure plate
Old Jan 7, 2013 | 06:38 PM
jbpnoman's Avatar
If it was the pressure plate, your speedometer wouldn't be reading anything. If it was the diff, same deal. The VSS reads off the transmission - if the tranny isn't spinning, your speedo wouldn't be rolling.
You just replaced the axle, then this problem started? Or did the car work fine afterwards, then this started? I would still double check your axles.
Old Jan 7, 2013 | 06:41 PM
Fliptard's Avatar
Axle probably isn't in all the way, or popped back out. Had this issue before.
Old Jan 7, 2013 | 06:44 PM
this happened then i realized the axle was messed up.... so i replaced the axle n it didnt fix a thing... if the axles weren't in correctly it would be leaking transmission fluid and its not
Old Jan 7, 2013 | 07:29 PM
jbpnoman's Avatar
It wouldn't necessarily be leaking transmission fluid. Are the CV joints FLUSH with the transmission?
Old Jan 7, 2013 | 07:32 PM
dirty19's Avatar
Ridin Dirty in Cali
If the axels arent in all the way this will happen period.
They dont necessarilly leak... they just wont engage.
Check them again just like JPB said.
Old Jan 7, 2013 | 10:13 PM
Psychoteen101's Avatar
By "the axle was messed up", what exactly do you mean?
Old Jan 7, 2013 | 11:31 PM
hwyix's Avatar
What he said and several of the other members said. Most likely your axles are not all the way in.
92eghatchGSR
Feb 17, 2008 08:16 PM
NA_VTEC
May 7, 2006 09:20 AM
93preludes
Aug 14, 2003 05:56 AM
